10-AM Commandments Sixth Edition
Contents
    Volume 16 Number 2  September 2009
+ Admission for creation of an AV fistula
ACS 1438 Chronic kidney disease, kidney replacement therapy provides the following classification advice:
  1. Cases of chronic kidney disease with ongoing kidney replacement therapy, whether by dialysis or by transplant, which comply with ACS 0002, require a code from N18.- Chronic kidney disease to describe the current stage of disease, except in routine dialysis only admissions.
  2. For routine dialysis only admissions it can be assumed from the assignment of Z49.1 Extracorporeal dialysis or Z49.2 Other dialysis that the patient has CKD - stage 5 (see also ACS 1404 Admission for kidney dialysis).
Does the same apply for patients admitted for creation of an AV fistula? Is a CKD code required, or should CKD only be assigned if it meets the criteria in ACS 0002 Additional diagnoses?
When a patient is admitted specifically for creation of an AV fistula assign Z49.0 Preparatory care for dialysis as the principal diagnosis. An additional code for CKD should be assigned if it meets the criteria in ACS 0002 Additional diagnoses.
+ Alcohol poisoning
When should the code for acute alcohol intoxication (F10.0) versus poisoning by alcohol (T51.0) be assigned?
Clinical advice indicates that alcohol poisoning is a particularly severe form of alcohol intoxication. Typically, alcohol poisoning is characterised by major disturbance of conscious level, inability to rouse the patient and resultant threat to life requiring supportive treatment.
Coders should be guided by the documentation in the clinical record. Where acute alcohol intoxication is documented, assign F10.0 Mental and behavioural disorders due to the use of alcohol, acute intoxication following the index pathway:
Intoxication
- alcoholic (acute) (with) F10.0
Where alcohol poisoning is documented, assign T51.0 Toxic effect of alcohol, Ethanol following the index pathway:
Poisoning (acute) (see also Table of drugs and chemicals)
Table of Drugs and Chemicals
Alcohol
- beverage T51.0
and appropriate external cause of injury codes.
See also ACS 0503 Drug, alcohol and tobacco use disorders and ACS 1903 Two or more drugs taken in combination.
+ Anaemia in neoplastic disease
Please clarify the following:
a. For a patient admitted with the following additional diagnoses:
Anaemia and melaena ? cause
Patient is transfused with 1 unit of packed red blood cells (Hb 9.2)
Patient is also noted to have prostate cancer, not treated or investigated at this admission and
therefore does not meet ACS 0002 Additional diagnoses for code assignment.
Should the anaemia be coded to D63.0 Anaemia in neoplastic disease with additional codes for
the neoplasm assigned or should the anaemia alone be coded?
The index pathway for 'Anaemia, in neoplastic disease' should not be followed in the scenario cited where the 'anaemia' and 'melaena' are clearly documented as due to an unknown cause. In this instance code the anaemia alone.
b. The following advice was issued in Coding Matters Vol 6, No 1:
'Code D63.0* Anaemia in neoplastic disease should be assigned when anaemia occurs in, due to or with a neoplastic condition. The specific code for the neoplasm should be assigned when known, as indicated by the inclusion term:
Conditions in Chapter 2 (C00-D48).'
Does this advice still apply?
The NCCH acknowledges there has been difficulty in applying this advice, particularly where the anaemia is unrelated to the neoplasm. It was not intended for this code to be assigned where the anaemia has been documented as due to an unknown cause or a non-neoplastic condition.
The codes in category D63 Anaemia in chronic diseases classified elsewhere have been revised for ICD-10-AM Seventh Edition.
+ Art therapy
Should there be an allied health code in ACHI for art therapy?
ACHI contains a number of codes in block [1916] Generalised allied health interventions that identify specific allied health specialties. ACHI also contains an intervention code for art therapy, 96181-00 [1873] Art therapy.
ACS 0032 Allied health interventions provides the following advice for assignment of general and specific allied health intervention codes:
'... clinical coders are encouraged to use the more specific codes for allied health interventions to better represent the interventions performed.'
Therefore, assign specific allied health intervention codes where the documentation is available. So for documentation of art therapy in the clinical record, assign 96181-00 [1873] Art therapy.
+ Bairnsdale ulcer
What is the correct code for a Bairnsdale ulcer?
A Bairnsdale ulcer is synonymous with a Buruli ulcer, which is indexed in ICD-10-AM. Therefore, the correct code to assign for a Bairnsdale ulcer is A31.1 Cutaneous mycobacterial infection.
Improvements to the Alphabetic Index will be considered for a future edition of ICD-10-AM.
+ BK virus
What is the correct code to assign for BK virus?
The BK virus is a type of human polyomavirus that infects most people but generally causes no symptoms. The virus was first isolated in 1971 from the urine of a renal transplant patient, with initials B.K.
This virus is normally latent, however, it may be reactivated in immunocompromised or immunosuppressed patients. It is believed to be the cause of nephropathy, nephritis and haemorrhagic cystitis in organ transplant recipients.
The correct code to assign for BK virus is B97.8 Other viral agents as the cause of diseases classified to other chapters by following the index pathway:
Infection, infected
- virus NEC
- - specified type NEC
- - - as cause of disease classified elsewhere B97.8
Codes from category B95-B97 Bacterial, viral and other infectious agents are not intended for use as principal diagnoses. As indicated in the code titles, they are provided for use as supplementary or additional codes to identify the infectious agent(s) in diseases classified elsewhere. See 10-AM Commandments Vol. 13 No. 4.
+ Correction of forefoot deformity
A patient is admitted for correction of a forefoot deformity. The ACHI pathway, Correction, deformity, bony assigns 90604-00 [1578] Correction of bony deformity in the Limb reconstruction block, which does not appear correct. The body of the operation report describes the exact procedure as an arthrodesis of the 1st metatarsophalangeal (MTP) joint and four osteotomies of separate toes with internal fixation. What is the correct code assignment?
'Correction of forefoot deformity' is a general description. Coders should be guided by the details of the procedure documented in the operation report for specific code assignment.
The correct codes to assign for the scenario cited are 49845-00 [1543] Arthrodesis of first metatarsophalangeal joint and 48403-01 [1528] Osteotomy of toe with internal fixation x 4, following the pathways:
Arthrodesis (with fixation device)
- metatarsophalangeal, 1st 49845-00 [1543]
and
Osteotomy
- toe
- - with internal fixation 48403-01 [1528]
The NCCH will consider improvements to the Alphabetic Index for a future edition of ACHI.
+ Descmets Stripping Endothelial Keratoplasty (DSEK)
What is the correct code for Descmets Stripping Endothelial Keratoplasty (DSEK)?
DSEK is a type of partial thickness keratoplasty.
ACHI does not contain a specific code for partial thickness keratoplasty (including DSEK). The correct code to assign for this procedure is 90064-00 [173] Other keratoplasty.
+ Food challenges
What is the correct code(s) to assign for a patient admitted for a peanut challenge, who does not exhibit symptoms of allergy themselves, but is having the challenge because a sibling has a severe peanut allergy?
There are no guidelines in ICD-10-AM or the ACS for code assignment for patients admitted specifically for food challenges, and analysis of current coding practice has highlighted inconsistencies.
Patients who are admitted for a food challenge due to a personal history of allergy (where challenge demonstrates the allergy is no longer present) should be assigned a code from category Z03 Medical observation and evaluation of suspected diseases and conditions with an additional code Z88.8 >Personal history of allergy to other drugs, medicaments and biological substances.
For the scenario cited, where there is a family history of food allergy, assign Z03.6 Observation for suspected toxic effect from ingested substance and Z84.8 Family history of other specified conditions, following the pathways:
Observation
- suspected (undiagnosed) (unproven)
- - toxic effects from ingested substance (drug) (poison) Z03.6
and
History (of) (personal)
- family, of
- - allergy NEC Z84.8
+ Fracture of hip prosthesis due to trauma
ACS 1309 Dislocation of hip prosthesis states:
'Cases where the patient sustains a traumatic dislocated hip prosthesis should be assigned code S73.0- Dislocation of hip...'
So an injury code is assigned. Does this ACS also apply to fractures of hip prostheses due to trauma, ie should an injury code be assigned or is T84.0 Mechanical complication of internal joint prosthesis the correct code?
The guidelines in ACS 1309 Dislocation of hip prosthesis do apply to fractures of hip prostheses due to trauma. Appropriate injury and external cause of injury codes should be assigned to reflect the trauma.
T84.0 Mechanical complication of internal joint prosthesis should be assigned where the conditions listed in T82.0 are specified as due to the joint prosthesis, as per the inclusion term at T84.0 and also following the criteria in ACS 1309 Dislocation of hip prosthesis.
+ Idiopathic Infantile Arterial Calcification (IIAC)
What is the correct code to assign for idiopathic infantile arterial calcification?
Idiopathic infantile arterial calcification is a rare disorder with diffuse disease of elastic and muscular arteries. It is characterised by destruction and fragmentation of the arterial internal elastic membrane, deposition of calcium along the internal elastic membrane and intimal proliferation. The coronary arteries are most commonly involved and in most cases, death is usually due to congestive heart failure and myocardial infarction.
There is no specific index entry in ICD-10-AM for idiopathic infantile arterial calcification (IIAC). The correct code to assign is Q28.8 Other specified congenital malformations of circulatory system.
Improvements to the Alphabetic Index will be considered for this condition for a future edition of ICD-10-AM.
+ Ileocolic resection
When a portion of the ileum is removed along with the caecum the procedure is called an ileocolic resection. There is no index entry for this procedure, so what code(s) should be assigned?
ACHI does not contain a specific code for ileocolic resection. Assign 30566-00 [895] Resection of small intestine with anastomosis and 32003-00 [913] Limited excision of large intestine with anastamosis, to accurately reflect the procedure performed, by following the pathways:
Excision
- intestine
- - small (with anastomosis) 30566-00 [895]
and
Colectomy
- local - see Colectomy, limited
- limited (local) (with anastomosis) 32003-00 [913]
If stoma formation is specified in the procedure, select the index entry ?with formation of stoma? in the index pathways above and assign the appropriate codes.
+ Insertion of fiducial markers into the prostate
What is the correct code for insertion of fiducial markers into the prostate?
Fiducial markers are implantable devices used as a tool in image-guided radiotherapy (IGRT). The markers may also be called fiducial seeds or gold seed markers. Gold seeds are the most frequently used markers. The seeds are inserted into the prostate via a needle using transrectal ultrasound. Several days after insertion of the seeds treatment planning by CT simulation is commenced.
There is currently no specific code in ACHI for insertion of fiducial markers into prostate, therefore assign 90395-00 [1170] Other procedures on prostate.
A specific code for this procedure has been included in ACHI Seventh Edition.
+ Molecular Adsorbent Recirculating System (MARS) treatment
What is the correct code to assign for MARS treatment?
MARS treatment is an extracorporeal, liver support therapy. It is a mechanical detoxification system designed to selectively eliminate both water-soluble toxins (as in renal dialysis) and strongly albumin-bound toxins in the blood of patients with liver insufficiency. It supports the liver until it is capable of spontaneous recovery or it may serve as a bridge to transplantation.
ACHI does not contain a specific code for MARS treatment. Assign 13750-06 [1892] Other therapeutic haemapheresis.
+ Multiple coding of procedures
Should arterial, PICC or CVC lines, MRI and nuclear medicine scans be coded as many times as they are performed ie multiple times during an admission?
Where arterial, PICC or CVC lines, MRIs or nuclear medicine scans are inserted/performed as stand alone procedures under an anaesthetic (except local), assign a code as many times as performed, as per the principles in ACS 0042 Procedures normally not coded.
Where multiple arterial, PICC or CVC lines, MRIs and nuclear medicine scans are performed as stand alone procedures, but not performed under anaesthetic, or are performed under a local anaesthetic only, assign a code for the procedure once only.
Where NCCH has not published advice to exempt the coding of specific procedures/interventions multiple times, or they are not listed in ACS 0042 or ACS 0020, they should be coded as many times as they are performed. For example, thoracentesis, paracentesis or lumbar punctures should be coded each time they are performed during an episode of care.
See also, 10-AM Commandments Central venous and arterial lines, Vol 15, No 1, June 2008 and advice issued regarding the coding of multiple CT scans in FAQs, part 2 published in Coding Matters Vol 15, No 3, Dec 2008 and advice regarding the insertion of Hickman's line in FAQs published in this edition of Coding Matters, Vol 16, No 2.
These issues have been addressed for the Seventh Edition of ICD-10-AM/ACHI/ACS.
+ Osteomyelitis of knee due to Burkholderia pseudomallei infection
What is the correct code assignment for osteomyelitis of the knee due to Burkholderia pseudomallei infection?
Osteomyelitis is an unusual but well recognised manifestation of melioidosis, a disease that is endemic in South-East Asia and northern Australia. Infection is caused by Burkholderia pseudomallei which can be acquired by ingestion, inhalation or wound contamination. Infection more commonly occurs in people with coexistent conditions such as diabetes, renal impairment, chronic pulmonary disease and immunosuppression. Subacute presentations often mimic other disease processes and patients may not always be clinically septic.
Treatment for osteomyelitis often requires surgical drainage and multiple antibiotic therapy.
The correct codes to assign for the scenario cited above are M86.86 Other osteomyelitis, lower leg and B96.88 Other and unspecified bacterial agents as the cause of diseases classified to other chapters, following the pathways:
Osteomyelitis (infective) (septic) (suppurative)
- specified NEC M86.8-
and
Burkholderia NEC
- pseudomallei (see also Melioidosis)
- - as the cause of disease classified elsewhere B96.88
or
Infection, infected
- Burkholderia NEC
- - pseudomallei (see also Melioidosis)
- - - as the cause of disease classified elsewhere B96.88
+ Procedural complications
What is the correct code to assign for an intraoperative cardiac arrest with successful resuscitation - I97.8 Other postprocedural disorders of circulatory system, not elsewhere classified or T81.8 Other complications of procedures, not elsewhere classified?
For a procedural complication occurring during surgical care (as per the above scenario) refer to ACS 1904 Procedural complications which states:
'There are a number of terms used in ICD-10-AM to describe procedural complications and these generally relate to the timing of the complication.
Misadventure
A misadventure is defined as a complication occurring during medical or surgical care. It may be noted at the time of the procedure or after completion of the procedure.'
Then follow the guidelines for classification of procedural complications which states:
'Firstly, check the Alphabetic Index under the main term which best describes the complication, for the subterm of 'procedural' or 'postprocedural'.'
Therefore, for this scenario, follow the index pathway:
Arrest, arrested
- cardiac
- - postprocedural I97.8
and assign I97.8 Other postprocedural disorders of circulatory system, not elsewhere classified with I46.0 Cardiac arrest with successful resuscitation to provide further specification of the condition (as per ACS 1904) and the appropriate external cause of injury codes.
Do not follow the index pathway Arrest, cardiac, complicating, surgery and assign T81.8 as this is contrary to the guidelines in ACS 1904.
Improvements to the Alphabetic Index in relation to procedural complications will be considered for a future edition of ICD-10-AM
+ Radiofrequency ablation of stellate ganglion
What is the correct code to assign for radiofrequency ablation of stellate ganglion?
The correct code to assign for radiofrequency ablation of the stellate ganglion is 39323-00 [72] Other percutaneous neurotomy by radiofrequency by following the pathway:
Ablation
- nerve - see also neurotomy
Neurotomy
- peripheral
- - percutaneous, by
- - - radiofrequency 39323-00 [72]
Improvements to the ACHI Alphabetic Index for this procedure will be considered for a future edition.
+ Use of abbreviations and symbols
When can coders use abbreviations and symbols documented in the clinical record to assign conditions, eg
↓ Hb or Hb 98 documented and transfusion given - can anaemia be assigned?
↓ K or K2.9 documented and potassium supplements commenced - can hypokalaemia be assigned?
Clinicians sometimes use abbreviations and symbols to document conditions in the clinical record. Each case should be assessed on its own merits to determine if the documentation sufficiently describes a condition that meets the criteria in ACS 0001 Principal diagnosis or ACS 0002 Additional diagnoses, in order to be coded.
When ↓Hb or ↓K is documented as the indication for an intervention such as a blood transfusion or commencement of medication, a code for the condition can be assigned if the test result or clinician confirms that the patient's haemoglobin or potassium is below the normal range; as the criteria for code assignment in ACS 0001 or ACS 0002 has been met. See ACS 0010 General abstraction guidelines.
So, where ↓Hb is documented as the indication for a transfusion and the test results and/or clinician verifies the patient's haemoglobin is below the normal range - follow the index pathway, Low, haemoglobin and assign D64.9 Anaemia, unspecified.
Where ↓ K is documented as the indication for commencement of medication and the test results and/or clinician verifies the patient's potassium is below the normal range, follow the index pathway Deficiency, potassium (K); Depletion, potassium; Hypokalaemia; or Hypopotassaemia and assign E87.6 Hypokalaemia.
However, if ICD-10-AM does not provide an index look up or there is uncertainty or ambiguity in relation to such abbreviated forms of documentation, they should be confirmed with the clinician prior to code assignment. Coders should not assign codes on the basis of test results alone.
+ Bibliography
Fuller, C.F & Scarbrough T.J, Fiducial Markers in Image-guided Radiotherapy of the Prostate. Accessed 20 August 2009. http://www.touchoncology.com/files/article_pdfs/onco_6729
Nandurkar, D & Lau, K, Melioidosis as a Cause of Multifocal Osteomyelitis, Clinical Nuclear Medicine, Volume 31(1), January 2006, pp 25-27. Accessed 15 July 2009. http://journals.lww.com/nuclearmed/Abstract/2006/01000/Melioidosis_as_a_Cause_of_Multifocal_Osteomyelitis.9.aspx
Novelli, G, Rossi, M, Ferretti, G, Nudo, F, Bussotti, G, Mennini, L, Ferretti, S, Antonellis, S, Martelli, S, Berloco, P.B, Molecular Adsorbent Recirculating System Treatment for Acute Hepatic Failure in Patients with Hepatitis B Undergoing Chemotherapy for Non-Hodgkin's Lymphoma, Transplant Proceedings, Volume 37, Issue 6, July-August 2005, Pages 2560-2562. Accessed 20 August 2009. http://www.sciencedirect.com
Popoff, I, Nagamori, J & Currie, B, Melioidotic Osteomyelitis in Northern Australia, ANZ Journal of Surgery, Volume 67, Issue 10 (p 692-695). Published Online 21 January 2008. Accessed 15 July 2009. http://www3.interscience.wiley.com/cgi-bin/fulltext/119163131/PDFSTART
The Fetus Net, Aortic calcinosis. Accessed 21 August 2009. http://www.thefetus.net/page.php?id=1178
The Free Dictionary, BK Virus. Accessed 21 August 2009. http://medical-dictionary.thefreedictionary.com/BK+virus
WrongDiagnosis.com, BK Virus Infection. Accessed 21 August 2009. http://www.wrongdiagnosis.com/b/bk_virus_infection/intro.htm
+ FAQ's
The following FAQs were asked at the recent ICD-10-AM/ACHI/ACS Sixth Edition 2009 continuing education coding workshops. The standard abbreviation of 'ACS' has been used throughout for 'Australian Coding Standard'.
As many of the FAQs raised at the workshops were case specific, it is recommended that coders review these answers with the workbook to help understand the context of the responses.
The workshop books are still available for purchase for those who couldn't attend a workshop, please refer to our website: http://www.fhs.usyd.edu.au/ncch and follow the link to the 2009 Coding workshops (ICD-10-AM/ACHI/ACS Sixth Edition)
+ Q1:
Q1: In case scenario 3 the patient was admitted for insertion of a biventricular pacemaker due to CCF. Why was a code assigned for the haematoma, isn't this complication considered an expected outcome of this type of surgery?
A: In this case scenario the patient developed a wound haematoma at the pocket site where the generator for the pacemaker was inserted as indicated by the following documentation:
Haematoma noted at 1700 hours post IPPM. 10 minutes of manual pressure applied over site. Site was initially marked at 1700 hours and monitored with no increase in haematoma size since then. Seen by doctor and a pressure bandage was applied at 1800 hours. Information regarding the PPM was given to the patient and she was discharged at 1830 hours
Where a catheter is inserted through the femoral vein, a haematoma at the puncture site is quite common. These haematomas usually resolve. However, in this case the haematoma was monitored by the nursing staff and then reviewed by the clinician to assess the size of the haematoma and apply a pressure bandage etc. Therefore, it meets the criteria in ACS 0002 and the following codes were assigned:
T82.8 Other complications of cardiac and vascular prosthetic devices, implants and grafts
Y83.1 Surgical operation with implant of artificial internal device
Y92.22 Place of occurrence, health service area
+ Q2:
Q2: If a patient is admitted for insertion of a biventricular pacemaker and following the procedure develops a wound haematoma, can an additional code be assigned for contusion of thorax?
A: Yes, S20.2 Contusion of thorax can be assigned as an additional code to further specify the type of complication as per ACS 1904, 'An additional code from Chapters 1 to 19 may be assigned to provide further specification of the condition.'
+ Q3:
Q3: If an intraoperative haemorrhage occurs during, for example the insertion of a pacemaker as seen in case scenario 3, which is the correct code to assign T81.0 Haemorrhage and haematoma complicating a procedure, not elsewhere classified or T82.8 Other complications of cardiac and vascular prosthetic devices, implants and grafts?
A: Follow the excludes note at T81.0 Haemorrhage and haematoma complicating a procedure, not elsewhere classified and assign the most appropriate code:
Haemorrhage at any site resulting from a procedure
Excludes:
haematoma of obstetric wound (O90.2)
haemorrhage due to or associated with prosthetic
devices, implants and grafts (T82.8, T83.8,
T84.8, T85.8)
'associated with' was added to the excludes note in Sixth Edition at T81.0 as there doesn't need to be a cause and effect relationship between the device, implant or graft and the haemorrhage for T82.8 to be assigned.
+ Q4:
Q4: Why was I25.2 Old myocardial infarction and Z95.5 Presence of coronary angioplasty implant and graft assigned in case scenario 3?
A: In this case scenario there is documentation that the patient was admitted for insertion of a biventricular pacemaker due to CCF 'on a history of recurrent MI, ... history of stenting of RCA and LAD four years previously'. Codes have been assigned for these conditions, as per ACS 0940 Ischaemic heart disease - Old myocardial infarct (I25.2) and Chronic ischaemic heart disease (I25.9) and ACS 2112 Personal history, because the history of old myocardial infarct and coronary implant status is documented as being directly relevant to the current episode of care (or is linked to the condition currently being treated).
+ Q5:
Q5: In case scenario 4:
Principal diagnosis
Bradycardia
History
ESRD secondary to CKD
Hypertension
Mitral regurgitation
Gout
Patient was transferred from another hospital dialysis centre on 11/8 for investigation and management of chest pain and bradycardia. He was noted to have chest pain while receiving dialysis and his heart rate was 40bpm. Following transfer he was still experiencing some dizziness and chest pain which was eventually relieved by GTN?
Why was chest pain coded and should it have been the principal diagnosis?
A: R07.4 Chest pain, unspecified was coded as an additional diagnosis as it met the criteria in ACS 0002 Additional diagnoses - the condition was a problem on admission and it was treated with GTN.
In selecting a condition as the principal diagnosis ACS 0001 Principal diagnosis should be followed. Within this ACS guidelines are provided for when 'two or more conditions, each potentially meeting the definition for principal diagnosis' occurs and the clinician should be asked to indicate which diagnosis best meets the principal diagnosis definition. In this scenario the bradycardia and chest pain both could have equally met the definition of principal diagnosis however the clinician has then indicated that the principal diagnosis was bradycardia.
+ Q6:
Q6: In case scenario 4 an ECG was performed which 'showed no acute changes, however, ventricular bigeminy was noted'. Should a code for ventricular bigeminy be assigned?
A: 'Ventricular bigeminy refers to alternating normal sinus and premature ventricular complexes. Three or more successive premature ventricular complexes are arbitrarily defined as ventricular tachycardia. Premature ventricular complexes become more prevalent with increasing age and occur in association with a variety of stimuli. It is important to determine whether underlying structural heart disease is present and left ventricular function is impaired. Other common causes include electrolyte abnormalities, stimulants, and some medications.' (http://www.aafp.org/afp/20020615/2491.html - Journal of the American Academy of Family Physicians)
Ventricular bigeminy noted on the ECG is not coded as per ACS 0010 General abstraction guidelines - Test results. The clinician has not indicated a relationship between this finding and a condition OR indicated its significance.
+ Q7:
Q7: Why was fluid overload coded in case scenario 5 when it is a symptom of chronic kidney disease?
A: In this scenario the patient was initially admitted for investigation of acute on chronic renal failure however the focus of the admission was the management of fluid overload. As per ACS 0002 Additional diagnoses - Problems and underlying conditions:
'If a problem with a known underlying cause is being treated, then both conditions should be coded (see also ACS 0001 Principal diagnosis, Problems and underlying conditions). '
Therefore in this case scenario a code has been assigned for fluid overload (E87.7) as it was documented that the condition did not improve after 10 days treatment.
+ Q8:
Q8: If a patient with acute on chronic kidney disease is transferred to another hospital within 24-48 hrs of admission what code is assigned for the chronic component of the disease?
A: As per Coding Matters (FAQs) Vol 15, No 2, September 2008:
'In this scenario assign N18.9 Chronic kidney disease, unspecifiedfor the chronic component of the disease as the eGFR will not be a true indicator of the underlying level of kidney function. However if 'end-stage' is documented or the patient is on ongoing haemodialysis or peritoneal dialysis then N18.5 Chronic kidney disease, stage 5 would be assigned.'
+ Q9:
Q9: When should Z91.1 Personal history of noncompliance with medical treatment be assigned?
A: ACS 0517 Noncompliance with treatment provides the following guidelines:
'Z91.1 Personal history of noncompliance with medical treatment and regimen should be used where noncompliance is a precipitating factor in an admission. It should not be used as a principal diagnosis.'
These guidelines were developed specifically for the coding of mental health episodes of care where noncompliance with medication commonly exacerbates the patient's condition, resulting in their admission to hospital. This code may also be assigned in other circumstances if it meets the criteria in ACS 0002 Additional diagnoses. ACS 0517 will be reviewed for a future edition.
+ Q10:
Q10: Why wasn't the Hickman's line insertion coded in case scenario 6?
A: Insertion of the Hickman's catheter was not assigned in this case scenario as it was the route of administration for the haemodialysis. As per ACS 0042 Procedures normally not coded:
'These procedures are normally not coded because they are usually routine in nature, performed for most patients and/or can occur multiple times during an episode. Most importantly, the resources used to perform these procedures are often reflected in the diagnosis or in an associated procedure. That is, for a particular diagnosis or procedure there is a standard treatment which is unnecessary to code.'
Changes are being made to this area of the classification for Seventh Edition to provide specific guidance on the coding of IV lines and catheters. See also advice in 10-AM Commandments - Multiple coding of procedures, published in Coding Matters Vol 16, No 2, September 2009.
+ Q11:
Q11: What is the principal diagnosis if a patient is admitted with multiple microvascular complications of their diabetes?
A: Refer to ACS 0401 Diabetes mellitus and impaired glucose regulation - Diabetes with multiple microvascular and other specified nonvascular complications. The following coding principles can assist in code assignment:
  • Only assign E1-.71 as the principal diagnosis when no one microvascular complication is the focus of the admission
  • If, for example, the nephropathy complication is the focus of the admission assign as the principal diagnosis E1-.2- followed by the chapter specific code as appropriate. E1-.71 is then assigned as an additional diagnosis together with any other specific complication codes as appropriate to indicate the patient has multiple microvascular complications.
+ Q12:
Q12: Could you please clarify the coding of excision of skin lesions in point 5 of ACS 0020 Bilateral/multiple procedures?
For example, if a patient is admitted for excision of a BCC on the forearm and a compound naevus on the breast and both are excised during the same visit to theatre, what code(s) would be assigned?
A: ACS 0020 Bilateral/multiple procedures has the following sections:
Bilateral procedures
  1. Procedures with a bilateral code
  2. Inherently bilateral procedures
  3. Procedures with no code option for bilateral
Multiple procedures
  1. The SAME PROCEDURE repeated during the episode of care at different visits to theatre
  2. The SAME PROCEDURE repeated during a visit to theatre involving ONE ENTRY POINT/APPROACH and similar/same lesions
  3. The SAME PROCEDURE repeated during a visit to theatre involving ONE ENTRY POINT/APPROACH and different lesions
  4. The SAME PROCEDURE repeated during a visit to theatre involving MORE THAN ONE ENTRY POINT/APPROACH and more than one non-bilateral site
  5. Skin or subcutaneous lesion removal
Point 5 - Skin or subcutaneous lesion removal - Assign the relevant code for excision of multiple lesions. In the scenario cited, two lesions have been removed from different sites, ACHI assigns the same code for these two sites therefore assign 31205-00 [1620] Excision of lesion(s) of skin and subcutaneous tissue of other site once only, as per the following index pathway:
Excision - see also Removal
- lesion(s) - see also Excision, tumour and Excision, cyst and Excision, polyp
- - skin and subcutaneous tissue
- - - specified site NEC 31205-00 [1620]
- - - - ankle 31235-04 [1620]
- - - - calf 31235-03 [1620]
- - - - cheek 31235-00 [1620]
- - - - ear 31230-02 [1620]
- - - - - wedge 45665-02 [1663]
- - - - eyelid 31230-00 [1620]
- - - - - wedge 45665-01 [1662]
- - - - finger 31230-04 [1620]
- - - - foot 31235-04 [1620]
- - - - forehead 31235-00 [1620]
- - - - genitals 31230-05 [1620]
- - - - hand 31235-02 [1620]
- - - - head NEC 31235-00 [1620]
- - - - hip 31235-03 [1620]
- - - - knee 31235-03 [1620]
- - - - leg 31235-03 [1620]
- - - - lip (see also Excision, lesion(s), lip) 31230-03 [1620]
- - - - - wedge 45665-00 [1664]
- - - - neck 31235-01 [1620]
- - - - nose 31230-01 [1620]
- - - - penis 31230-05 [1620]
- - - - pre and postauricular region 31235-00 [1620]
- - - - scrotum 31230-05 [1620]
- - - - thigh 31235-03 [1620]
- - - - thumb 31230-04 [1620]
- - - - toe 31235-04 [1620]
- - - - vulva 31230-05 [1620]
- - - - wrist 31235-02 [1620]
The following examples can assist in code assignment:
  • single or multiple forehead skin sites eg assign 31235-00 [1620] once only
  • lesion(s) removed from hip, thigh and knee assign 31235-03 [1620] once only as ACHI provides the same code for these sites
  • lesion(s) removed from hand and foot assign 31235-02 [1620] and 31235-04 [1620] as ACHI provides a separate code for each site.
+ Q13:
Q13: In case scenario 7 why was the revision of the burns scar coded 8 times when the procedure was only performed on both the left and right leg, therefore shouldn't this procedure have only been coded twice?
A: As per ACS 0020 Bilateral/multiple procedures - Multiple procedures point 4 - the same procedure repeated during a visit to theatre involving more than one entry point/approach and more than one non-bilateral site.
'Assign a code for each procedure as there is a separate entry point/approach for each one.'
In this case a total of 8 revisions of the burn scars were performed, 6 on the right leg and 2 on the left with separate entry points for each, therefore a total of 8 procedures were performed. Laterality doesn't apply to skin as the skin is considered one organ therefore the reference to left and right leg is irrelevant and point 4 is followed.
+ Q14:
Q14: What is the difference between:
O72.0 Third-stage haemorrhage
O72.2 Delayed and secondary postpartum haemorrhage and
O73.0 Retained placenta without haemorrhage
O73.1 Retained portions of placenta and membranes, without haemorrhage?
A: The difference between these two groups of codes is that the term 'without haemorrhage' has to be documented before assigning O73.0 or O73.1 as per the following index pathway where 'without haemorrhage' is an essential modifier:
Retention, retained
- placenta (total) (with haemorrhage) O72.0
- - without haemorrhage O73.0
- - portions or fragments (with haemorrhage) O72.2
- - - without haemorrhage O73.1
ICD-10-AM defaults to 'with haemorrhage' unless 'without' is clearly documented.
+ Q15:
Q15: The term 'pre-existing' is used in the code titles for O99.02 Anaemia complicating pregnancy, with mention of pre-existing anaemia and O99.04 Anaemia complicating childbirth and the puerperium, with mention of pre-existing anaemia, what does the term 'pre-existing' mean?
A: In ICD-10-AM 'pre-existing anaemia' refers to an anaemia which exists prior to the current pregnancy. A note defining 'pre-existing anaemia' will be included in the Tabular List in a future edition.
+ Q16:
Q16: Can Z35.51 Supervision of primigravida with advanced maternal age be assigned as an additional code in case scenario 8 where 'a 37 y.o. primigravida' was documented?
A: No, this code should not be assigned based on documentation of age alone. When only the age of the patient is documented (?35 years) without any qualifying statements to indicate that the age of the patient has had an impact on the patient's care this code should not be assigned as per ACS 0002 Additional diagnoses and ACS 1524 Advanced maternal age.
+ Q17:
Q17: Can a code from category O42 Premature rupture of membranes be assigned from the times documented on the partogram for when labour was established?
A: No, a code from this category should not be assigned based on documentation of the times for the establishment of labour alone. Therefore 'premature rupture of membranes' must be documented and must meet the criteria in either ACS 0001 Principal diagnosis, ACS 0002 Additional diagnoses or ACS 1531 Premature rupture of membranes before it can be coded.
+ Q18:
Q18: In case scenario 9 a patient was admitted following a multi vehicle collision with suspected C6/7 paraplegia, test results revealed:
MRI - central cord contusion and defect at C6/7 CT (with contrast) - diffuse lesion at C6/7, no displacement of cord.
As central cord syndrome has not been documented should S14.10 Injury of cervical spinal cord, unspecified be assigned instead of S14.12 Central cord syndrome (incomplete cord injury) of cervical spinal cord?
A: Central cord syndrome (CCS) is an acute incomplete cervical spinal cord injury (SCI). This syndrome, usually the result of trauma, is associated with damage to the large nerve fibres that carry information directly from the cerebral cortex to the spinal cord. The segment of spinal cord affected by central cord syndrome is the cervical segment, the part of the spinal cord that is encased within the first seven vertebrae, running from the base of the brain and into the neck.The cord syndromes describe the area (almost cross sectionally) of the spinal cord that has been affected by the lesion (ie contusion/haemorrhage etc). A common cause of this type of injury includes trauma.
Any injury or condition that preferentially damages the central, grey matter of the cervical spinal cord can lead to central cord syndrome. The most common causes include complications of the progressive, degenerative spinal disease called spondylosis, as well as traumatic injury to the cervical spine, such as fractures or dislocations. The diagram below illustrates the location of the injury to the spinal cord.
Central cord lesion/contusion/injury are all synonymous terms that describe a central cord syndrome and an MRI can show direct evidence of spinal cord impingement from bone, disc, or haematoma - therefore S14.12 is the most appropriate code to assign in this case. A central cord contusion can be assumed to be central cord syndrome as any injury of the central cord is effectively a central cord syndrome. The indexing of this condition will be reviewed for a future edition.
http://www.answers.com/topic/central-cord-syndrome
http://www.ninds.nih.gov/disorders/central_cord/central_cord.htm
http://www.healthline.com/galecontent/central-cord-syndrome
http://www.neurosurgerytoday.org/what/patient_e/central_cord_syndrome_06.asp
+ Q19:
Q19: Does there need to be a causal link between jaundice and prematurity for P59.0 Neonatal jaundice associated with preterm delivery to be assigned?
A: No, the index indicates that the jaundice can be 'due to or associated with' preterm delivery.
+ Q20:
Q20: Does sedation need to be coded with ventilation when it is administered?
A: As per ACS 0031 Anaesthesia, a code is assigned for any form of anaesthetic except local anaesthesia and oral sedation, when administered for anaesthetic purposes to perform a procedure ie for intubation/ventilation.
+ Q21:
Q21: In clinical record 2 the acute renal failure was documented as being due to dehydration and medications. Should N17.8 Other acute kidney failure be assigned?
A: There is a 'specified NEC' pathway in the index under Failure, kidney, acute. However, when checking the Tabular List we can see that the axis at the fourth character level specifies the type and site of necrosis rather than specifying the cause of the renal failure. The appropriate code to assign in this case is, therefore, N17.9 Acute kidney failure, unspecified.
+ Q22:
Q22: Should patient controlled analgesia (PCAs) be coded as per the hierarchy in ACS 0031 Anaesthesia - Classification point 5?
A: Codes for PCAs in Fifth Edition were only assigned if 'data was required at the local hospital level'. This entry was removed from ACS 0031 in Sixth Edition to reinforce coding consistency at a national level. However no changes were made to the hierarchy of codes in the ACS:
[1912] Postprocedural analgesia
  1. Management of neuraxial block (92516-00)
  2. Management of regional block (codes 92517-00, 92517-01, 92517-02, 92517-03)
  3. Subcutaneous postprocedural analgesic infusion (90030-00)
  4. Intravenous postprocedural infusion, patient controlled analgesia (PCA) (92518-00)
  5. Intravenous postprocedural analgesic infusion (92518-01)
Subcutaneous and intravenous postprocedural analgesic infusions should not be coded and ACS 0031 will be amended in Seventh Edition to reflect this advice with points iii-v being deleted in the above hierarchy of codes.
+ Q23:
Q23: Why was bradycardia in clinical record 5 coded as a procedural complication and assigned a misadventure code for the external cause?
A: In this record bradycardia was coded as a procedural complication following clinical advice which indicated that bradycardia was related to the procedure being performed:
'During an endoscopy a patient can become ?vagal? due to the stimulation of the bowel, this produces bradycardia which sometimes may need to be treated with a vagal blocker like atropine. This is considered an effect of having the procedure and therefore can be caused by the endoscopy.'
Therefore, as per ACS 1904 Procedural complications, bradycardia meets the definition of a procedural complication:
A condition or injury which is directly related to a surgical/procedural intervention.
Although the bradycardia is not documented as being 'due to' the procedure it was 'related' to the procedure as per the definition above. There is documentation on the discharge summary that the patient developed bradycardia intraoperatively and the operation report indicated that the procedure was 'limited' because of this condition.
Once this definition is met follow the classification guidelines for the coding of a symptom:
Symptoms which meet the criteria of procedural complications
When a procedural complication is a symptom classifiable to Chapter 18 Symptoms, signs and abnormal clinical and laboratory findings, not elsewhere classified, assign an appropriate chapter specific 'postprocedural disorder' code, followed by the code for the symptom and the appropriate external cause codes.
and assign:
I97.8 Other postprocedural disorders of the circulatory system, not elsewhere classified
R00.1 Bradycardia, unspecified
As bradycardia occurred intraoperatively it meets the criteria for a misadventure as per the following definition in ACS 1904:
'Misadventure
From the documentation we know the complication occurred intraoperatively and the external cause code then identifies the timing of the complication. Assign Y65.8 Other specified misadventures during surgical and medical care as per the following classification guidelines:
Misadventure
A code from block Y60-Y69 Misadventures to patients during surgical and medical care should be assigned when the complication occurs during a procedure.
Refer to the main term of 'Misadventure' in the ICD-10-AM Index to External Causes of Injury, and then by the type of misadventure.'
Improvements to the Alphabetic Index are being considered for a future edition.
+ Q24:
Q24: In clinical record 5 why was diverticulosis assigned as the principal diagnosis given the patient was being admitted for investigation of anaemia and melaena as per ACS 0046 Diagnosis selection for same-day endoscopy?
A: In this case a discharge summary was completed by the clinician which indicated the principal diagnosis was sigmoid diverticulosis. The intent of ACS 0046 is to provide guidelines to coders for the coding of same-day cases where a number of conditions may meet the definition of principal diagnosis and no guidance is provided by the clinician. However, this case provides a discharge summary which clearly indicates the principal diagnosis.
Additional codes were assigned for the anaemia and melaena (refer to ACS 1102 Gastrointestinal (GI) haemorrhage) and as the contact bleeding (transverse colon) occurred at a different site to the diverticulosis (sigmoid colon) no link has been made between these two conditions.
+ Q25:
Q25: Why was a short colonoscopy coded in clinical record 5?
A: The operation report in this record indicated that the colonoscopy was only able to be passed to the transverse colon, therefore 32084-00 [905] Fibreoptic colonoscopy to hepatic flexure is the correct code to assign. A long colonoscopy goes beyond the hepatic flexure as per the index pathway in ACHI:
Colonoscopy (beyond hepatic flexure) (fibreoptic) (long) (to caecum) 32090-00 [905]
- to hepatic flexure (short) 32084-00 [905]
The following diagram illustrates the anatomy of the colon and where a short and long colonoscopy passes to:
+ Q26:
Q26: Why was Z06.99 Agent resistant to other single specified antibiotic assigned in clinical record 6?
A: There was documentation on the discharge summary and in the progress notes that the E. coli (found on MSU) was resistant to Keflex. ACS 0112 Infection with drug resistant microorganisms indicates that:
'If the clinician has documented in the record that the organism causing the infection is resistant to an antibiotic, then the appropriate code from Z06.- Bacterial agents resistant to antibiotics must also be assigned.
A code from category Z06.- Bacterial agents resistant to antibiotics is assigned as an additional code to identify the antibiotic to which a bacterial agent is resistant.'
It should be noted that a code from this category should not be assigned based on microbiology sensitivity results alone.
+ Q27:
Q27: Why was I25.9 Chronic ischaemic heart disease, unspecified assigned in clinical record 6, wouldn't I25.2 Old myocardial infarction be more specific?
A: In this record IHD was noted on the discharge summary as one of the associated conditions for the episode of care. During the admission an echocardiogram was performed and the indication for this intervention was IHD, therefore this condition meets ACS 0002 for code assignment.
ACS 0940 Ischaemic heart disease provides guidelines on the assignment of I25.9. As this record does not provide any additional information in the current episode of care and there is no access to previous admission notes which could indicate the specificity of the IHD (ie coronary atherosclerosis I25.1-), I25.9 is assigned.
I25.2 Old myocardial infarction would not be assigned as the condition does not meet the classification guidelines in ACS 0940:
I25.2 Old myocardial infarction is essentially a 'history of' code, even though it is not included in the Z code chapter. It should be assigned as an additional code only if all of the following criteria apply:
  • the 'old' myocardial infarction occurred more than four weeks (28 days) ago;
  • the patient is currently not receiving care (observation, evaluation or treatment) for their 'old' myocardial infarction; and
  • the 'old' myocardial infarction meets the criteria in ACS 2112 Personal history.
    Volume 16 Number 1  June 2009
+ Combination drug coding
How should poisoning/adverse effect due to combination drugs be coded? For example, Mersyndol, which is a combination of 3 drugs; codeine, paracetamol and doxylamine succinate.
If a combination drug is documented as the cause of a poisoning/adverse effect - and no individual component is identified as being responsible for the poisoning/adverse effect, assign a code for each of the components.
Example 1: Patient admitted with poisoning by Mersyndol (codeine, paracetamol and doxylamine succinate). No individual component of the Mersyndol was identified as the cause of the poisoning.
Table of Drugs and Chemicals:
Codeine...T40.2
Doxylamine...T45.0
Paracetamol...T39.1
Assign:
T40.2 (Poisoning by) Other opioids
T45.0 (Poisoning by) Antiallergic and antiemetic drugs
T39.1 (Poisoning by) 4-Aminophenol derivatives
With a code for any significant manifestation that meets the criteria in ACS 0002 Additional diagnoses, plus appropriate external cause, place of occurrence and activity codes.
If a combination drug is documented as the cause of a poisoning/adverse effect - and one of the components is identified as causing the poisoning/adverse effect, assign a code for that drug only. Code(s) for the other components of the combination drug are not required.
Example 2: Patient admitted with bronchospasm due to ingestion of Mersyndol (codeine, paracetamol and doxylamine succinate) - taken as directed on the packet, for menstrual cramps. The codeine was documented as the cause of the bronchospasm.
Codeine...Y45.0
Assign:
J98.0 Diseases of bronchus, not elsewhere classified
Y45.0 (Drugs ...causing adverse effects in therapeutic use) Opioids and related analgesics
With appropriate place of occurrence code.
See also ACS 1901 Poisoning and ACS 1902 Adverse effects.
+ Complications of surgical and medical care
a. Headache due to anaesthesia
How do you code headache due to anaesthesia (other than spinal and epidural anaesthesia)?
To code headache due to anaesthetic drugs or anaesthesia in ICD-10-AM Sixth Edition, follow the guidelines in ACS 1904 Procedural complications and ACS 1902 Adverse effects, Drugs.
For headache due to anaesthetic drugs, follow the index pathway:
Headache
- drug induced NEC G44.4
and assign G44.4 Drug-induced headache, not elsewhere classified with an external cause code to identify the drug.
If the headache is specified as due to anaesthesia, but not specifically the anaesthetic drugs, follow the index pathway:
Complications
- anaesthesia, anaesthetic NEC (see also Anaesthesia, complication or reaction NEC) T88.5
and assign T88.5 Other complications of anaesthesia with R51 Headache as an additional diagnosis to complete the clinical picture.
b. Leaking gastrostomy tube
What is the correct code assignment for leaking gastrostomy tube?
To assign a code for leaking gastrostomy tube follow the guidelines in ACS 1904 Procedural complications:
"Firstly, check the Alphabetic Index under the main term which best describes the complication, for the subterm of 'procedural' or 'postprocedural'...
In some cases, rather than the generic term 'postprocedural', the subterm may directly describe the procedure involved."
Therefore, the correct code to assign is T85.5 Mechanical complication of gastrointestinal prosthetic devices, implants and grafts by following the index pathway:
Leak, leakage
- device, implant or graft
- - gastrointestinal (bile duct) (oesophagus) T85.5
with Y83.3 Surgical operation with formation of external stoma and Y92.22 Health service area.
c. Postprocedural bile leak
What is the correct code assignment for postprocedural bile leak?
When postprocedural/anastomotic bile leakage is documented but trauma or mechanical complication (conditions listed in T82.0) due to gastrointestinal implant is not specified, assign K91.8 Other postprocedural disorders of the digestive system, not elsewhere classified, following the index pathway:
Complication
- digestive
- - postprocedural
- - - specified NEC K91.8
K83.8 Other specified diseases of biliary tract may be assigned as an additional code to specify the site of the postprocedural/anastomotic bile leak.
Where there is documentation that the postprocedural/anastomotic bile leak is due to trauma or mechanical complication (conditions listed in T82.0), assign the appropriate codes from Chapter 19 Injury, Poisoning and Certain Other Consequences of External Causes (S00-T98) as per the guidelines in ACS 1904 Procedural complications. For example, for a postprocedural/anastomotic bile leak due to:
  • operative trauma - assign T81.2 Accidental puncture and laceration during a procedure, not elsewhere classified with the appropriate injury code (S code) to identify the site of the trauma.
  • mechanical complication (conditions listed in T82.0) due to a gastrointestinal implant - assign T85.5 Mechanical complication of gastrointestinal prosthetic devices, implants and grafts.
In addition, assign external cause of injury and place of occurrence codes as appropriate
+ Deep inferior epigastric perforator (DIEP) flap for breast reconstruction
What is the correct code to assign for a DIEP flap for breast reconstruction?
The correct code to assign for a DIEP flap for breast reconstruction is 45530-00 [1756] Reconstruction of breast using myocutaneous flap. Even though a DIEP flap does not use myocutaneous tissue, myocutaneous is a nonessential modifier in the Alphabetic Index, despite being specified in the code title.
The NCCH will review the code title of 45530-00 [1756] for a future edition of ACHI.
+ Duodenoscope assisted cholangiopancreatoscopy (DACP)
What is the correct procedure code to assign for duodenoscope assisted cholangiopancreatoscopy?
Duodenoscope assisted cholangiopancreatoscopy (DACP) allows direct visualisation of the biliary and pancreatic ducts. It is beneficial in circumstances where direct ductal visualisation is helpful in clarifying a diagnosis or providing targeted treatment that is not possible with conventional fluoroscopic imaging.
The procedure was first described in the mid-1970s when endoscopic retrograde cholangiopancreatoscopy (ERCP) was in its infancy. The procedure involves a small calibre cholangiopancreatoscope (daughter scope or baby scope) being passed through the accessory channel of the duodenoscope and is used to cannulate the ampulla of Vater and obtain images of the bile duct and then the pancreatic duct.
The technique, however, was not widely accepted due to expensive and inadequate instruments which suffered frequent breakage, poor optics, etc.
However, in recent years technological improvements have overcome the inadequate equipment of the past and DACP may expand management options for pancreaticobiliary disorders in the future.
The correct code assignment for DACP is:
30442-00 [957] Choledochoscopy
and
30473-00 [1005] Panendoscopy to duodenum
+ Elevated prostate specific antigen (PSA)
What is the correct principal diagnosis selection for a day stay urology admission where 'elevated PSA' alone is documented as the principal diagnosis on the discharge summary and as the indication on the operation report but where the histopathology report received after discharge indicates adenocarcinoma?
Prostate specific antigen (PSA) is a protein that is secreted into ejaculate which helps to nourish the sperm. Normally, only tiny amounts enter the bloodstream. However, cancer cells and other conditions can interfere with proper functioning and cause large amounts to enter the blood. It is currently the most widely used method to screen for prostate cancer.
It is acknowledged that elevated PSA is also an indicator of other conditions such as benign prostatic hyperplasia (BPH), urinary tract infections and prostatitis. For the scenario cited, where histopathology has confirmed a diagnosis of adenoacarcinoma, this should be assigned as the principal diagnosis. The adenoacarcinoma should be coded as a finding that adds specificity to the diagnosis of 'elevated PSA' as per the guidelines in ACS 0010 General abstraction guidelines,test results.
Clinical advice has confirmed that R79.8 Other specified abnormal findings of blood chemistry is the correct code to assign for elevated PSA.
+ Excisional debridement
Should an additional code for suture of wound be assigned with 30023-01 [1566] Excisional debridement of soft tissue involving bone or cartilage as it does not contain an includes note for suture of wound as in 30023-00 [1566] Excisional debridement of soft tissue
30023-00 [1566] Excisional debridement of soft tissue has the following note:
'Includes: suture of wound'
This has led some coders to assume that as there is no similar note at 30023-01 [1566] Excisional debridement of soft tissue involving bone or cartilage, that any suture of the wound should be assigned as an additional code for this procedure as it does not contain the same includes note.
However, in these circumstances the guidelines in ACS 0016 General Procedure Guidelines - Procedure Components apply and it is unnecessary to assign an additional code for suture of wound performed with excisional debridement. It is a component of the procedure.
The 'includes' note at 30023-00 [1566] will be reviewed for a future edition of ACHI.
+ Fall while water skiing
What is the correct external cause code to assign for fall causing injury (other than drowning/submersion injury) while water skiing?
The correct external cause code to assign for fall from water skis causing injury (other than drowning/submersion injury) is W02.2 Fall involving water ski following the index pathway:
Fall, falling (accidental)
- involving
- - conveyance, pedestrian
- - - not in collision with pedestrian
- - - - ski(s)
- - - - - water W02.2
Water ski accidents may be classified as a pedestrian conveyance or water craft accident depending on the circumstances of the accident. However, clinical advice from the National Injury Surveillance Unit (NISU) confirmed that W02.2 Fall involving water ski describes this accident more specifically than the residual code V94.7 Other and unspecified water transport accidents, water skis and should, therefore, be assigned in this instance.
+ Human immunodeficiency virus (HIV) in pregnancy
Should a code from Chapter 15 Pregnancy, Childbirth and the Puerperium be assigned in addition to a code for human immunodeficiency virus [HIV] disease (B20-B24) for HIV complicating pregnancy, delivery or the puerperium?
There is no index entry specifically for HIV complicating pregnancy and there is an exclusion note for 'human immunodeficiency virus [HIV] disease (B20-B24)' at O98 Maternal infectious and parasitic diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium. Therefore, it is unnecessary to assign a code from Chapter 15 Pregnancy, Childbirth and the Puerperium in addition to a code from B20-B24 for HIV complicating pregnancy, childbirth or the puerperium.
Z33 Pregnant state, incidental may be assigned as an additional code for episodes of care where a patient is admitted for HIV and is pregnant as per the advice in ACS 1521Conditions complicating pregnancy, Incidental pregnant state.
+ Incontinence
Please clarify ACS 1808 Incontinence below in relation to the following:
1808 INCONTINENCE
Incontinence is clinically significant when the incontinence:
  • is not clinically considered to be physiologically normal,
  • is not clinically considered to be developmentally normal, or
  • is persistent in a patient with significant disability or mental retardation.
Urinary and faecal incontinence codes (R32 Unspecified urinary incontinence, R15 Faecal incontinence) should be assigned only when the incontinence is persistent prior to admission, is present at discharge or persists for at least seven days.
a. Should coders use the information in the first paragraph of the ACS to determine if the incontinence is 'clinically significant' before following the classification advice in the second paragraph or is this paragraph for information only?
b. When following the classification advice in the second paragraph, would a code for incontinence be assigned for any patient, with any length of stay (including same day) admitted for any condition who was incontinent once only, providing it was on their day of discharge. That is, would you assign an additional code for incontinence for a same day admission of an elderly patient where voluminous incontinence is noted but is not the principal reason for admission?
c. Does this ACS cover all types of urinary incontinence or only those classifiable to R32 Unspecified urinary incontinence
R32 Unspecified urinary incontinence and R15 Faecal incontinence should be assigned if they meet the criteria in ACS 0001 Principal diagnosis or ACS 0002 Additional diagnoses.
Additionally, advice in ACS 1808 Incontinence should be followed. Therefore, in answer to part (a) of this query, the first paragraph is for information only.
In answer to part (b), coders should apply the advice in the second paragraph where the intent is to code 'persistent' faecal and/or urinary incontinence. So, for a same day episode of care, the advice to assign a code for incontinence present at discharge should only be followed where the documentation confirms that incontinence is a persistent problem.
Lastly, in answer to part (c), the advice in ACS 1808 is for urinary incontinence classifiable to R32 Unspecified urinary incontinence, only. It does not apply to other types of urinary incontinence e.g. overflow, stress incontinence etc.
+ Intercostal neuralgia
What is the correct code assignment for intercostal neuralgia?
The current index entries under Neuralgia and Neuritis do not include a subterm for intercostal. This may lead coders to assign G58.8 Other specified mononeuropathies. However, the index entry for Neuropathy has a subterm for intercostal, which assigns G58.0 Intercostal neuropathy, which is the correct code assignment for intercostal neuralgia.
Indexing improvements to this area of ICD-10-AM have been made for Seventh Edition.
+ In vitro fertilisation (IVF)
Please clarify the advice under In vitro fertilisation (IVF) in ACS 1437 Infertility concerning the assignment of an additional code from N97 Female infertility.
1437 INFERTILITY
When a female is admitted specifically for IVF procedures, and the principal diagnosis is 'IVF' or 'infertility', Z31.2 In vitro fertilisation should be assigned as the principal diagnosis code. An additional code from category N97 Female infertility, for the type of infertility may be assigned if known, including N97.4 Female infertility associated with male factors.
The intent of the advice in the above paragraph is that female patients admitted specifically for 'IVF' with documented 'infertility' should have Z31.2 In vitro fertilisation assigned as the principal diagnosis. A code classifiable to N97 Female infertility should be assigned as an additional code to specify the type of infertility, including N97.9 Female infertility, unspecified for female infertility NOS. It is not necessary to assign a code from category N97 if the reason for the IVF is not specified or it is performed for another reason.
+ Ischaemic fingers
Ischaemic fingers due to occlusion of blood vessel secondary to injecting crushed benzodiazepine tablets into the ulnar artery.
What is the correct code assignment for the above scenario?
The correct codes to assign for this scenario are:
T42.4 Poisoning by antiepileptic, sedative-hypnotic and antiparkinsonism drugs, Benzodiazepines
I77.8 Other specified disorders of arteries and arterioles
Assign a more specific code if the type of blood vessel occlusion is specified e.g. I74.2 Embolism and thrombosis of arteries of upper extremities for thrombosis of ulnar artery.
+ Neonatal withdrawal due to maternal use of prescribed medication.
What is the correct code to assign for a neonate suffering withdrawal due to maternal use of prescribed pain medication during pregnancy?
The correct code to assign for the neonate in this scenario is P96.1 Neonatal withdrawal symptoms from maternal use of drugs of addiction following the index pathway:
Reaction
- drug NEC
- - withdrawal
- - - newborn P96.1
The assignment of this code is not affected by whether or not the mother is drug dependent.
+ Parafoveal telangiectasia
What is the correct code assignment for parafoveal telangiectasia treated by Avastin® injection into retinal blood vessels?
Parafoveal or perifoveal telangiectasia, also known as macular telangiectasis, is a peculiar retinal vascular disorder that affects the central portion of the macula.
Dilated retinal capillaries occur around the temporal aspect of the foveal area, eventually encircling it completely causing progressive loss of vision.
The correct code to assign for parafoveal telangiectasia is H35.0 Background retinopathy and retinal vascular changes following the pathway:
Disease, diseased
- retina, retinal
- - vascular lesion H35.0
or
Lesion
- retina, retinal
- - vascular H35.0
Avastin®(Bevacizumab) works by blocking a substance known as vascular endothelial growth factor (VEGF). Blocking or inhibiting VEGF helps prevent further growth of blood vessels. Initially, the drug was approved for the treatment of metastatic colorectal cancer to block blood vessels that the cancer needs to continue growing.
More recently ophthalmologists have injected Avastin® into the posterior chamber of the eye to treat age related macular degeneration and other eye conditions that cause loss of vision due to abnormal growth of blood vessels in the back of the eye, such as parafoveal telangiectasia. The drug was used because research indicated that VEGF is one of the causes for the growth of the abnormal vessels that cause these conditions.
The correct code to assign for Avastin® injection into abnormal retinal blood vessels is 42740-03 [209] Administration of therapeutic agent into posterior chamber following the index pathway:
Injection
- posterior chamber (by paracentesis) (eye) (therapeutic agent) 42740-03 [209]
The NCCH will consider improvements to the index for this condition and procedure for a future edition of ICD-10-AM/ACHI.
+ Periductal mastitis
What is the correct code to assign for periductal mastitis?
The International Classification of Diseases, Tenth Revision, Clinical Modification (ICD-10-CM), used in the United States, assigns periductal mastitis to mammary duct ectasia while ICD-10-AM makes no such link.
A literature review reveals that periductal mastitis has been confused with and called duct ectasia. However, duct ectasia is almost certainly a separate condition affecting an older age group and characterised by subareolar duct dilatation and less pronounced and less active periductal inflammation. Current evidence suggests that smoking is an important factor in the aetiology of periductal mastitis but not in duct ectasia.
Therefore, the correct code to assign for periductal mastitis is N61 Inflammatory disorders of breast following the index pathway:
Mastitis (acute) (infective) (nonpuerperal) (subacute) N61
+ Poisoning
ACS 1901 Poisoning states that 'In addition to the code for poisoning, an additional code should be assigned to indicate any significant manifestation (e.g. coma, arrhythmia).'
In a scenario where a patient is transferred to an Intensive Care Unit (sedated/ventilated) from another hospital following carbon monoxide poisoning/benzodiazepine overdose and it is noted that an arrhythmia was treated at the scene, can this ACS be applied (i.e. can a code for the arrhythmia be assigned) at the receiving hospital where the condition is no longer present?
ACS 1901 Poisoning intends to provide guidance on the sequencing of code assignment for poisoning episodes of care. It highlights that in addition to a code from the poisoning chapter an additional code may be assigned for any 'significant manifestations.' It was not intended to expand the interpretation of 'significant manifestations.'
Coders should follow the criteria in ACS 0001 Principal diagnosis or ACS 0002 Additional diagnoses to determine if a code for a manifestation of poisoning should be assigned.
+ Pyelonephritis with renal calculus and hydronephrosis
What is the correct code assignment for pyelonephritis with renal calculus and hydronephrosis?
The correct code assignment for pyelonephritis with calculus and hydronephrosis is N13.2 Hydronephrosis with renal and ureteral calculus obstruction following the pathway:
Pyelonephritis
- with calculus
- - - with hydronephrosis N13.2
If the condition is documented with an infection, N13.6 Pyonephrosis may also be assigned with an additional code (B95-B97) to identify any infectious agent, to complete the clinical picture. See also ACS 0027 Multiple coding and ACS 0033 Conventions used in the tabular list of diseases.
+ Soft tissue injuries (STIs)
Can you clarify ACS 1331 Soft tissue injuries, particularly in relation to contusions which are classified as superficial injuries rather than soft tissue injuries?
Soft tissue injuries include damage to muscles, ligaments and tendons. They usually fall into one of the following:
  • contusions (bruises)
  • sprains
  • strains
A contusion is an injury to soft tissue often produced by a blunt force such as a kick, fall or blow.
A sprain is an injury to a ligament and is often caused by a wrench or twist.
While a strain is an injury to a muscle or tendon and is often caused by overuse, force or stretching.
ACS 1331 Soft tissue injuries advises that where a more specific injury is documented (e.g. contusion, sprain or strain), these should be coded rather than following the index pathway 'Injury, site.'
Where soft tissue injury is the only description documented for an injury, assign a code by following the index pathway 'Injury, site.'
ICD-10-AM, as per ICD-10, classifies 'contusion' as a superficial injury, however, this does not alter the classification advice above.
The NCCH will review ACS 1331 Soft tissue injuries for a future edition of the ACS.
+ Bibliography
ASGE, Technology Status Evaluation Report Gastrointestinal Endoscopy Vol 50, NO. 6, 1999, Duodenoscope-Assisted Cholangiopancreatoscopy. Accessed 1 December 2008. http://louisville.edu/medschool/medicine/gastro/media/ASGE%20Manual/content/7/7-08.pdf
Avastin®(Bevacizumab) Intravitreal Injection, 2003 The Eye Hospital, Launceston, Tasmania. Accessed 13 May 2009. http://www.eyehospital.com.au/brochures/avastin_intravitreal_injection.pdf
Bowers, K, The Alfred Hospital, Inflammatory Diseases of the Breast. Accessed 12 May 2009. http://www.surgeons.org/AM/presentations/KBowers_050219.pdf
Dixon, J.M, ABC of Breast Diseases: Breast Infection, BMJ 1994;309:946-949 (8 October). Accessed 12 May 2009. http://www.bmj.com/cgi/content/full/309/6959/946
Thompson, C.C, Kelsey.P.B., Current Opinion in Gastroenterology, 19(5):487-491, 2003, Duodenoscope-assisted Cholangiopancreatoscopy: A Review of Clinical Applications. Accessed 1 December 2008. http://www.medscape.com/viewarticle/460478
MedGadget, Spyglass™Direct Visualization System to Cure ERCP Addiction. Accessed 1 February 2009. http://medgadget.com/archives/2007/05/spyglass_direct_visualization_system_makes_ercps.html
VirtualMedicalCentre.com, PSA (Prostate Specific Antigen) Testing. Accessed 20 March 2009. http://www.virtualcancercentre.com/healthinvestigations.asp?sid=67
Vitreous-Retina-Macula Consultants of New York, Idiopathic perifoveal telangiectasia. Accessed 3 March 2009. http://www.vrmny.com/pe/ipt.html
    Volume 15 Number 4  March 2009
+ Coding diabetes mellitus and impaired glucose regulation (IGR)
Note: The following advice on diabetes mellitus also applies to impaired glucose regulation (IGR)
During the 2008 Sixth Edition Coding Workshops, the NCCH emphasised that diabetes mellitus must meet ACS 0002 Additional diagnoses to be coded. The education highlighted that routine BSLs do not fall under the ACS 0002 criteria for 'increased clinical care and/or monitoring' and therefore can not be used by coders to determine when to code diabetes mellitus and any associated conditions.
It is acknowledged that there may be some variation in the way that diabetes mellitus is coded in Sixth Edition, mainly due to how the index deals with diabetes and its associated conditions. Coders should continue to code diabetes as they have been and follow the advice published as a 10-AM Commandment in Coding Matters, Volume 15, No.1, June 2008 Diabetes mellitus and blood sugar levels. The NCCH in conjunction with the Coding Standards Advisory Committee (CSAC) recognises that there will be instances throughout the life of Sixth Edition where coding advice on diabetes will be sought. It is therefore recommended that coding queries related to diabetes mellitus be dealt with at the state level during Sixth Edition.
+ Apophysiodesis of femur
What is the correct intervention code to assign for apophysiodesis of the femur?
The correct code to assign for apophysiodesis of the femur is 48500-00 [1491] Epiphysiodesis of femur. Clinical advice confirms that an apophysiodesis is the same as an epiphysiodesis of the femur, except that it is performed at the proximal end of the femur rather than the distal end, which is more common. Clinical advice also indicated that:
"Technically a growth point that leads to a muscle attachment is an apophysis whereas a growth plate to a joint is an epiphysis." Courtenay, Brett (personal communication, Orthopaedic Clinician).
+ Creation of arteriovenous fistulas for dialysis treatment
When should Z49.0 Preparatory care for dialysis be assigned for an admission for creation of an arteriovenous fistula and when should a complication code from category T82 Complications of cardiac and vascular prosthetic devices, implants and grafts be assigned?
Z49.0 Preparatory care for dialysis should be assigned for those admissions where the intention is for creation of a new fistula in preparation to commence dialysis treatment. Where the reason for creation of a new fistula is due to a complication relating to an existing fistula (even when the new fistula is being created at a different site), then assign the appropriate complication code from category T82 Complications of cardiac and vascular prosthetic devices, implants and grafts with external cause codes Y84.1 Kidney dialysis and Y92.22 Health service area.
+ External cause codes for renal dialysis
What is the correct external cause code assignment for complications related to renal dialysis?
Ureteral stents are an integral part of urological practice. Stents can migrate, fragment or be forgotten and a portion of these will become calcified. Treatment to render a patient stent-free in these circumstances includes ureteroscopy, percutaneous nephroscopy, cystoscopic electrohydraulic lithotripsy, extracorporeal shock wave lithotripsy, open cysto-litholapaxy and simple nephrectomy - or a combination of the above.
The correct code to assign for endoscopic lithotripsy of an encrusted ureteric stent is 36809-00 [1074] Endoscopic fragmentation of ureteric calculus. Calcified encrustation is considered calculous material, therefore, the correct pathway is Destruction, calculus, ureter. Assign also a code for removal of ureteric stent as appropriate
+ Excoriation skin of breast
What is the correct code to assign for non traumatic excoriation of skin of breast?
Non traumatic excoriation of skin of breast is also known as intertrigo.
Intertrigo is inflammation of skinfolds caused by skin-on-skin friction or chafing of warm, moist skin in areas such as the inner thighs and genitalia, the armpits, under the breasts, under abdominal folds, behind the ears and the web spaces between the fingers and toes.
The condition is particularly common in obese patients who are exposed to high heat and humidity, but it can occur in anyone.
The correct code to assign for non traumatic excoriation of skin of breast is L30.4 Erythema intertrigo.
+ Failure to progress in labour
What is the correct code to assign for failure to progress in labour?
Failure to progress in labour is a description rather than a diagnostic term, therefore a code for the underlying condition resulting in failure to progress should be assigned. Underlying causes may include cephalopelvic disproportion, malpresentation, inefficient uterine action, (primary uterine inertia or secondary uterine inertia), cervical dystocia, maternal exhaustion etc.
In the absence of documentation of an underlying cause for failure to progress, clinical advice indicates that the correct code to assign is O62.9 Abnormalities of forces of labour, unspecified.
+ Glaucoma with diabetes mellitus
For a diabetic patient with glaucoma NOS is it appropriate to assign E1-.39 * Diabetes mellitus with other specified ophthalmic complication and H40.9 Glaucoma, unspecified?
There is no index entry for 'Diabetes, with glaucoma' in ICD-10-AM, therefore E1-.39 * Diabetes mellitus with other specified ophthalmic complication should not be assigned in this scenario.
+ Macular degeneration with diabetes mellitus
Should E1-.34 * Diabetes mellitus with other retinopathy be assigned in addition to H35.3 Degeneration of macula and posterior pole in a patient with macular degeneration and diabetes mellitus?
There is no index entry for 'Diabetes, with macular degeneration' in ICD-10-AM. Clinical advice indicates that there is no cause and effect relationship between macular degeneration and diabetes mellitus and it is therefore, inappropriate to assign E1-.34 * Diabetes mellitus with other retinopathy in the above scenario. These conditions should be coded separately unless the clinician clearly documents a link such as diabetic maculopathy.
+ Sympathetic storm following traumatic brain injury
What is the correct code to assign for sympathetic storm following traumatic brain injury?
Sympathetic storming occurs in 15% to 33% of patients with severe traumatic brain injury who are comatose. It is an exaggerated stress response marked by agitation or restlessness and can be associated with fever, posturing, tachycardia, hypertension and diaphoresis. It is thought to be caused by an increase in activity of the sympathetic nervous system created by a disassociation or loss of balance between the sympathetic and parasympathetic nervous systems.
In addition to coding out the traumatic brain injury the NCCH advises that sympathetic storm should be classified to G90.8 Other disorders of autonomic nervous system by following the pathway(s):
Disorder
- autonomic nervous system
-- specified NEC G90.8
or
Imbalance
- autonomic G90.8
or
Imbalance
- sympathetic G90.8
Assign also codes for manifestations of the sympathetic storm, as appropriate, if they meet the criteria in ACS 0002 Additional diagnoses.
+ Unspecified gastroenteritis complicating pregnancy
What is the correct code to assign for unspecified gastroenteritis complicating pregnancy?
The correct code assignment for unspecified gastroenteritis complicating pregnancy is 098.8 Other maternal infectious and parasitic diseases complicating pregnancy, childbirth and the puerperium and A09.9 Gastroenteritis and colitis of unspecified origin.
+ Bibliography
Cauni, V, Geaviete, P, Georgescu, D, Mircliulescu, V. and Persu, C, Urology, Vol 68, Supplement 1, Novemeber 2006, Page 208, V-03.05 Endoscopic treatment in calcified ureteral stents. Accessed 26 August 2008. http://www.sciencedirect.com/science
DermIS, Dermatology Information System, Intertrigo. Accessed 1 February 2009. http://dermis.multimedica.de/dermisroot/en/12933/diagnose.htm
Janniger, C.K, Schwartz R.A, Szepietowski, J.C and Reich, A. American Family Physician, Sept 1, 2005, Intertrigo and Common Secondary Skin Infections. Accessed 1 February 2009. http://www.aafp.org/afp/20050901/833.html
Lemke, D.M, Critical Care Nurse Vol 27, No. 1, February 2007, Sympathetic Storming After Severe Traumatic Brain Injury. Accessed 9 December 2008. http://ccn.aacnjournals.org
Lemke, D.M, Journal of Neuroscience Nursing, 36 (1):4-9, 2004, Riding Out the Storm: Sympathetic Storming after Traumatic Brain Injury. Accessed 9 December 2008. http://www.medscape.com/viewarticle/469858
Monga, M, Klein, E, Castaneda-Zuniga, W.R, and Thomas, R, The Journal of Urology, Volume 153, issue 6, June 1995, Pages 1817-1819, The Forgotten Indwelling Ureteral Stent: A Urological Dilemma. Accessed 26 August 2008. http://www.sciencedirect.com/science
    Volume 15 Number 3  December 2008
+ ACS 1521 Conditions Complicating Pregnancy
+ ACS 1521 and adequate documentation to determine
that a condition has complicated a pregnancy
In the following scenario a pregnant female is admitted with a diagnosis of cholestasis but there is no documentation to suggest that cholestasis has complicated the pregnancy except for a note on discharge which states 'for antenatal clinic review next week with repeat LFTs and increased CTG monitoring,' is this adequate documentation to determine the condition has complicated the pregnancy?
A condition in pregnancy such as in the scenario cited above which requires increased CTG monitoring is sufficient documentation to indicate the condition has complicated the pregnancy.
Therefore the appropriate code from category O98 Maternal infectious and parasitic diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium or O99 Other maternal diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium should be assigned for conditions such as those in the scenario above, together with an additional code from the other chapters of ICD-10-AM to identify the specific condition, as per ACS 1521.
+ ACS 1521 and the postpartum period
Does the logic in ACS 1521 Conditions complicating pregnancy apply to the postpartum period?
ACS 1521 states:
'Chapter 15 Pregnancy, childbirth and the puerperium contains two blocks of codes for complications related to pregnancy, O20-O29 Other maternal disorders predominantly related to pregnancy and O94-O99 Other obstetric conditions, not elsewhere classified. Conditions that are known to occur commonly in pregnancy have specific codes in O20-O29. To code other conditions complicating pregnancy (or being aggravated by the pregnancy or that are the main reason for obstetric care), a code from O98 Maternal infectious and parasitic diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium or O99 Other maternal diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium is assigned, together with an additional code from the other chapters of ICD-10-AM to identify the specific condition.'
Historically, ICD-10 was developed for single condition coding, that is, only one code was assigned for each condition and therefore it was important to capture as much information as possible by one code assignment. The codes in category O99 Other maternal diseases classifiable elsewhere but complicating pregnancy, childbirth and the puerperium reflect this concept as they capture the fact that the patient is pregnant and that they have another condition (classifiable elsewhere) that is reflected in the code title. In Australia however, for morbidity coding, we follow the logic of multiple coding, as outlined in ACS 0027 Multiple coding and ACS 1521 Conditions complicating pregnancy and assign an additional code for the specific condition. This area of the classification is currently under revision as part of an overall review of obstetric coding being undertaken both nationally and internationally.
O80 Single spontaneous delivery as per ACS 1505 Single spontaneous delivery -
'is intended for single spontaneous vaginal deliveries:
without abnormality/complication classifiable elsewhere in Chapter 15 Pregnancy, childbirth and the puerperium and
without manipulation or instrumentation.'
The issue of how you determine whether a nonobstetric condition complicates or is aggravated by the pregnancy in the delivery episode of care (including the postpartum period) is problematic as past clinical advice indicates that even clinicians are unable to clearly define this. It is unlikely, therefore, that documentation will indicate whether a nonobstetric condition is complicating or aggravating the pregnancy in the delivery/postpartum episode of care. The rule of thumb for many coders appears to have been to assign a code from O98 or O99 as appropriate for nonobstetric conditions in this period and then to assign a code for the condition based on ACS 0027 Multiple coding.
That this practice should continue where there is a nonobstetric condition in the postpartum period of the delivery episode of care.
+ Anaesthetic Coding
Where intubation for an anaesthetic is indicated by terms such as LM3, PM3, LMA4 or laryngeal, but ventilation was spontaneous (i.e. not controlled) should it be coded as a general anaesthetic or sedation?
Where documentation is unclear as to the type of anaesthetic being administered follow the guidelines in ACS 0031 Anaesthesia. For classification purposes in ACHI and the ACS 'general anesthesia' is indicated by the use of an artificial airway, such as an endotracheal tube, laryngeal mask or Guedel airway (see ACS 0031 Anaesthesia, point 2, Sedation).
+ Anticoagulation therapy pre and post surgery
What is the correct code assignment for patients admitted prior and post surgery for anticoagulation therapy when the surgery is performed at another hospital?
The correct code assignment for a patient admitted for anticoagulant stabilisation prior to surgery to be performed at another hospital is:
Z51.4 Preparatory care for subsequent treatment, not elsewhere classified
Z92.1 Personal history of long term (current) use of anticoagulants
See also ACS 2103 Admission for convalescence/aftercare.
NB: If there is a contractual arrangement existing between the two hospitals in the scenario cited then the guidelines within ACS 0029 Coding of contracted procedures should also be followed.
+ Chronic Suppurative Lung Disease (CSLD)
What is the correct code to assign for CSLD?
Clinical advice indicates that 'CSLD is often called bronchiectasis.' Research further specified 'The term CSLD is used to describe a diagnosis where there are clinical symptoms of bronchiectasis without High Resolution Computed Tomography (HRCT) evidence of bronchiectasis. The dominant symptom of CSLD is the presence of excessively prolonged moist cough. Other than the lack of HRCT features, the symptoms of CSLD is otherwise identical to that of bronchiectasis.' Chang et.al (2008).
Therefore, the correct code to assign for this condition is J47 Bronchiectasis
+ Epstein-Barr Virus (EBV) hepatitis
How do you code Epstein-Barr Virus (EBV) hepatitis?
The Epstein-Barr virus, also called Human herpesvirus 4 (HHV-4), is a virus of the herpes family (which includes Herpes simplex virus) and is one of the most common viruses in humans. Most people become infected with EBV, which is often asymptomatic but commonly causes the clinical syndrome known as infectious mononucleosis or glandular fever.
Epstein-Barr virus infections can also be associated with hepatocellular hepatitis. The frequency of this association varies with age. It is estimated to be in 10% of young adults and 30% in the elderly where it presents itself as an anicteric viral hepatitis.
The correct codes to assign for EBV hepatitis are:
B17.8 Other specified acute viral hepatitis
B27.0 Gammaherpesviral mononucleosis
by following the index pathways:
Hepatitis
- viral, virus
-- specified type (with or without coma) NEC B17.8
and
Epstein-Barr virus (gammaherpesviral mononucleosis) B27.0
It is incorrect to classify EBV infections to category B00 Herpesviral [herpes simplex] infections. Although Epstein-Barr virus is a herpesviral infection, it is not a Herpes simplex infection and the excludes note for gammaherpesviral mononucleosis in B00 directs coders to B27.0 Gammaherpesviral mononucleosis, where mononucleosis due to Epstein-Barr virus is classified.
+ Failed/difficult intubation
When should a code for difficult intubation be assigned?
Difficult intubation is poorly defined in literature. It is sometimes described as repeated attempts at intubation, the use of bougie or other intubation aid.
The American Society of Anesthesiologists in their article entitled Practice Guidelines for Management of the Difficult Airway, Anesthesiology, V98, No 5, May 2003 state:
'A standard definition of the difficult airway cannot be identified in available literature. For these Guidelines, a difficult airway is defined as the clinical situation in which a conventionally trained anesthesiologist experiences difficulty with face mask ventilation of the upper airway, difficulty with tracheal intubation, or both.'
The following codes
T88.4 Failed or difficult intubation
Y84.8 Other medical procedures as the cause of abnormal reaction of the patient, or of later complication, without mention of misadventure at the time of the procedure
should only be assigned when the 'failed' or 'difficult' intubation meets the criteria in ACS 0002 Additional diagnoses. However, these codes should not be routinely assigned when 'difficult intubation' is documented.
+ Laser ablation of the lower ureter
What is the correct code to assign for laser ablation of the lower ureter?
Laser treatment is increasingly being used for a variety of urological procedures, including ablation of ureteric anastomotic and congenital strictures.
The correct code to assign for laser ablation of the lower ureter is 90358-00 [1088] Other procedures on ureter. Assign also the appropriate codes for endoscopy or stent insertion if performed.
+ Pelvic peritonitis secondary to pelvic inflammatory disease (PID) due to gonorrhoea
What are the correct codes to assign for pelvic peritonitis secondary to pelvic inflammatory disease due to gonorrhoea?
Pelvic inflammatory disease is a broad term encompassing a variety of upper genital tract infections such as salpingitis, salpingo-oophoritis, endometritis, tubo-ovarian inflammatory masses, and pelvic or diffuse peritonitis.
PID usually results from ascending infection from the cervix and is a common and serious complication of some sexually transmitted infections especially chlamydia and gonorrhoea. PID can damage the fallopian tubes and tissues in and near the uterus and ovaries. Untreated PID can lead to serious complications, including infertility, ectopic pregnancy, abscess formation and chronic pelvic pain.
The correct code assignment for pelvic peritonitis secondary to pelvic inflammatory disease due to gonorrhoea is:
A54.2Gonococcal pelviperitonitis and other gonococcal genitourinary infections
N74.3* Female gonococcal pelvic inflammatory disease
Gonorrhoea
- pelvis(acute)(chronic)
-- female pelvic inflammatory disease A54.2† N74.3*
+ Male sling procedure
What is the correct procedure code to assign for sling procedure for male stress incontinence?
Urinary incontinence is a significant problem in men who undergo prostate surgery. Persistent, long term incontinence (usually stress incontinence) in patients following radical prostatectomy is difficult to treat. There are a number of male sling procedures which use various techniques, including bone anchors, to support the bulbar urethra and help to achieve effective dynamic urethral resistance.
Following clinical advice the correct code to assign for male sling procedure is 37044-00 [1109] Retropubic procedure for stress incontinence, male.
+ Plasmapheresis
What is the correct code assignment for patients admitted for donor apheresis?
There are two types of patients admitted for donor apheresis. One type of donor is a patient with a known disease, such as a malignancy, admitted to donate their own cells for therapeutic reinfusion at a later date (autologous donation). In this scenario assign a code for the condition to be treated by the donated cells.
The other type of donor is a healthy donor, admitted to donate cells for infusion into another person (allogeneic donation). In this scenario, assign as the principal diagnosis Z51.81 Apheresis.
For patients admitted for therapeutic apheresis (eg plasmapheresis, leukapheresis etc.) assign as the principal diagnosis a code for the condition requiring treatment. It is unnecessary to also assign Z51.81 Apheresis as this information is specified by the procedure code.
See ACS 0301 Stem cell procurement and transplantation.
+ Plasmapheresis for Kidney Transplant
What are the correct codes to assign for plasmapheresis for ABO incompatible kidney transplant recipient?
Plasmapheresis in this scenario is one component of an immunosuppressant protocol for a patient who is to receive an ABO incompatible kidney transplant. Immune suppression reduces a normal immune response to prevent rejection of transplanted organs or cells.
The correct code to assign for same day prophylactic plasmapheresis for a patient who is to receive a kidney from an incompatible blood group donor is Z29.1 Prophylactic immunotherapy
Do not assign Z51.81 Apheresis as per the index entry 'Admission, plasmapheresis' as this is the code for a patient admitted for allogeneic donor apheresis (that is, a healthy donor admitted to donate cells for transplant into another person).
See also ACS 0301 Stem cell procurement and transplantation.
+ Ventilator associated pneumonia
What is the correct code to assign for ventilator associated pneumonia?
Ventilator associated pneumonia (VAP) is a hospital acquired bacterial pneumonia in patients who are on mechanical ventilatory support through an endotracheal tube or tracheostomy tube for at least 48 hours. Pneumonia occurs as a result of microbial invasion of the normally sterile lower respiratory tract, often where there is a defect in host defenses and/or a virulent or overwhelming invasion of organisms.
Contaminates may also enter the patient's lungs from condensation on the intubation drainage tubing or because intubation itself bypasses the natural barrier between oropharynx and trachea. Bronchoscopy, tracheal suctioning, manual ventilation, the supine position of the patient and the use of paralytic agents may also play a role in the development of bacterial pneumonia in these patients.
VAP complicates the course of up to 47% of intubated patients and may have a mortality rate as high as 50%.
Following the guidelines in ACS 1904 Procedural complications the correct code to assign for ventilator associated pneumonia (VAP) is J95.8 Other postprocedural respiratory disorders following the pathway:
Pneumonia
- postprocedural J95.8
Assign also an additional code for the type of pneumonia from the choices listed under the lead term Pneumonia, plus the following external cause codes:
Y84.8 Other medical procedures as the cause of abnormal reaction of the patient, or of later complication, without mention of misadventure at the time of the procedure, Other medical procedures
+ Bibliography
ASERNIPS, Kidney transplantation using incompatible blood group donors, February 2008. Accessed 11 November 2008: http://www.surgeons.org/AM/Template.cfm?Section=ASERNIP_S_NET_S_Database&Template=/TaggedPage/TaggedPageDisplay.cfm&TPLID=17&ContentID=4938
ASERNIPS, ProACT? Therapy for male stress urinary incontinence, October 2007. Accessed 10 November 2008: http://www.horizonscanning.gov.au/internet/horizon/publishing.nsf/Content/asernip-s-net-s-summaries-2007
Berry, Angela, CNC, Intensive Care Unit, Westmead Hospital, Sydney West Area Health Service, Ventilator Associated Pneumonia (VAP). Accessed 24 July 2008. http://intensivecare.hsnet.nsw.gov.au/five/doc/icuconnect/hospital%20contributions/2006/november_VAP_westmead.pdf
Chang et.al, Chronic Wet Cough: Protracted Bronchitis, Chronic Suppurative Lung Disease and Bronchiectasis, Pediatric Pulmonology 43:519-531. Accessed 23 October 2008 http://www.interscience.wiley.com
Friedman, N Deborah, Russo Philip L. Richards, Michael J, Surveillance for ventilator-associated pneumonia: the challenges and pitfalls, A report from the VOCNISS Coordinating Centre, Victoria, Australia, Vol.10 Issue 4, December 2005. Accessed 24 July 2008. http://www.publish.csiro.au/?act=view_file&file_id=HI05122.pdf
Hubner and Schlarp 2005, Treatment of incontinence after prostatectomy using a new minimally invasive device: adjustable continence therapy, BJU International, Vol 96, Issue 4 (p 587 - 594). Accessed 10 November 2008: http://www3.interscience.wiley.com/cgi-bin/fulltext/118670052/PDFSTART
Lawee, David, Mild Infectious Mononucleosis presenting with transient mixed liver disease, The College of Family Physicians of Canada. Accessed 29 July 2008 http://www.pubmedcentral.nih.gov/articlerender.fcgi?artid=1949255
Patient UK, Pelvic Inflammatory Disease (PID). Accessed 24 July 2008 http://www.patient.co.uk/showdoc/40000099
St. Vincent's Clinic, Dr Raji Kooner, Treatment Options, Laser Surgery. Accessed 11 November2008: http://www.roboticprostatesurgery.com.au/to_lasersurgery.html
Virology Down Under, Epstein-Barr Virus. Accessed 24 July 2008. http://www.uq.edu.au/vdu/VDUEBV.htm
Virtual Medical Centre.com, Pelvic Inflammatory Disease. Accessed 24 July 2008. http://www.virtualendocrinecentre.com/diseases.asp?did=791
+ FAQ's
This is the second of a two part series on FAQs which were asked at the ICD-10-AM/ACHI/ACS Sixth Edition education workshops held during April - June 2008.
Part 1 was published in the September Edition of Coding Matters refer Volume 15 No.2.
+ Principal/Additional diagnoses
Q: Does the term 'infectious' need to be documented with gastroenteritis before A09.0 Other gastroenteritis and colitis of infectious origin can be assigned, regardless of the patient's age?
A: Yes, documentation should support the fact that the gastroenteritis is caused by an infectious organism before assigning A09.0. Other gastroenteritis and colitis of infectious origin, irrespective of the patient's age.
+ Diabetes
Q: In ACS 0401 Diabetes mellitus and impaired glucose regulation - Eradicated conditions in diabetes example 8 has assigned E11.29 Type 2 diabetes mellitus with other specified kidney complication with N18.3 Chronic kidney disease, stage 3 as the patient has had a transplant, but if CKD is never eradicated (as per ACS 1438 Chronic kidney disease - Kidney replacement therapy) why not code it to the current condition i.e. E11.22 Type 2 diabetes mellitus with established diabetic nephropathy?
A: Kidney replacement therapy in the form of a transplant or dialysis never eradicates chronic kidney disease as per ACS 1438 Chronic kidney disease. In this scenario assign E11.22 Type 2 diabetes mellitus with established diabetic nephropathy and N18.3 Chronic kidney disease, stage 3 to indicate that the patient still has CKD and diabetes, and Z94.0 Kidney transplant status.
Q: The clinical information in ACS 0401 Diabetes mellitus and impaired glucose regulation - Visceral fat deposition/obesity/overweight indicates that:
The following BMI categories adopted by WHO only apply to Europid adults (> 18 years old),
not to individuals from other ethnic backgrounds:
  • Overweight (grade 1 obesity) is defined as a BMI of 25-29.9 kg/m2
  • Obesity (grade 2) as BMI 30-39.9 kg/m2
  • 'Morbid obesity' (grade 3) as BMI > 40 kg/m2
The classification guidelines then indicate:
E11.72, E13.72, E14.72 *Diabetes mellitus with features of insulin resistance or E09.72 Impaired glucose regulation with features of insulin resistance, as appropriate, should be assigned when one or more of the following is documented:
  • acanthosis nigricans
  • characteristic dyslipidaemia (elevated fasting triglycerides and depressed HDL-cholesterol)
  • hyperinsulinism
  • hypertension
  • increased intra-abdominal visceral fat deposition
  • 'insulin resistance'
  • nonalcoholic fatty (change in) liver
  • obesity (meeting recognised criteria or documented as ?morbid obesity")
Does this therefore indicate that the three grades of obesity meet the criteria for features of insulin resistance?
A: Yes, to clarify this, clinical advice was sought and confirmed that 'obesity' (ie documentation of obesity grades 1, 2 and 3 or 'overweight', 'obesity' or 'morbid obesity') meet the criteria for features of insulin resistance in Europid adults. When BMI only, is documented seek clarification from the clinician. Amendments will be made to this section of the standard to better reflect this advice.
Q: If you have diabetes documented in the patient's medical history as:
Diabetes
- nephropathy
- retinopathy
- cardiomyopathy
can you assume that it is 'diabetic cardiomyopathy'?
A: As per ACS 0401 Diabetes mellitus and impaired glucose regulation:
Diabetic cardiomyopathy (E1-.53)
A distinctive form of cardiomyopathy without significant atherosclerotic involvement of coronary arteries, may occur in diabetic patients and often causes cardiac failure. It is characterised by diastolic dysfunction confirmed by cardiac nuclear scanning and/or echocardiography.
Diabetic cardiomyopathy is indexed in ICD-10-AM as follows:
Cardiomyopathy (familial) (idiopathic) I42.9
- diabetic E1-.53
or
Diabetes, diabetic (controlled) (mellitus) E1-.9
- cardiomyopathy E1-.53
Clinical advice was sought on this topic which advised the following:
'Cardiomyopathy cannot be assumed to be 'diabetic' without confirmation involving the demonstration of diastolic ventricular dysfunction on nuclear medicine cardiac scanning. Additionally, the categorisation of cardiomyopathy as 'diabetic' excludes significant coronary artery disease with resultant cardiomyopathy (coded to I25.5) and other causes (coded to I42.6 - I42.7 and I43). In the absence of other apparent causes and specific confirmation on formal investigation, the cardiomyopathy should be coded to I42.9'
Therefore, in the scenario cited the form of documentation specified is not sufficient to assume diabetic cardiomyopathy as per the index and the clinical advice received. The other two conditions, nephropathy and retinopathy, are linked with diabetes in the index and it is sufficient for the appropriate diabetes codes to be assigned in this instance.
+ Drug and alcohol
Q: Why can't Y91.9 Alcohol involvement, not otherwise specified be assigned to indicate alcohol involvement in an injury/accident admission? In the past this code has been routinely assigned to identify that there has been alcohol involvement, although the patient may not have been intoxicated at the time they presented to hospital.
A: At some of the workshops coders indicated that the victim who is admitted to hospital is not the one who has actually used alcohol. It is often the perpetrator of the assault who was influenced by alcohol and therefore coders wanted to assign Y91.9 to reflect this. The classification was not designed to capture this level of detail and as indicated in ACS 0002 Additional diagnoses:
'the national morbidity data collection is not intended to describe the current disease status of the inpatient population but rather, the conditions that are significant in terms of treatment required, investigations needed and resources used in each episode of care'.
Also, as the title of category Y91 is 'Evidence of alcohol involvement determined by level of intoxication' the codes from this category cannot be assigned if the patient is not intoxicated at the time of admission to hospital. ACS 0503 Drug, alcohol and tobacco use disorders also indicates that these codes are not to be used for inpatient morbidity coding.
Q: When can Z72.1 Alcohol use be assigned?
A: The note in category Z72 Problems related to lifestyle indicates that: 'hazardous use is a pattern of substance use that increases the risk of harmful consequences for the user. In contrast to harmful use, hazardous use refers to patterns of use that are of public health significance despite the absence of any current disorder in the individual user'.
Therefore this code can only be assigned if the clinician indicates there has been hazardous use of alcohol. It should be remembered that a code for alcohol cannot be routinely assigned, as we do with smoking, because of the subjective nature of its usage i.e. when looking at age, sex, weight issues etc. and that code assignment is still dependent on the condition meeting the criteria in ACS 0002 Additional diagnoses.
Q: If alcohol involvement has necessitated an admission to hospital for treatment of an injury but no blood alcohol level is documented, what code should be used?
A: Category Y91 Evidence of alcohol involvement determined by level of intoxication is not to be used for inpatient morbidity coding as per ACS 0503 Drug, alcohol and tobacco use disorders. In the scenario cited to indicate that alcohol was involved, Z72.1 Alcohol use may be assigned if the patient was affected by alcohol at the time of the injury and no blood alcohol level has been documented.
Q: As the blood alcohol levels specified at Y90 Evidence of alcohol involvement determined by blood alcohol level do not always match what is documented in the clinical record or reported by hospital pathology laboratories, can the NCCH publish the mappings for this in Coding Matters?
A: The table below provides the equivalent laboratory ranges for blood alcohol level as reported in ICD-10-AM and may be used as a guide for code assignment:
+ Chronic kidney disease
Q: The default for 'diabetes with chronic kidney disease' is E1-.22 * Diabetes mellitus with established diabetic nephropathy, why isn't E1-.21 * Diabetes mellitus with incipient diabetic nephropathy assigned as this is the 'lesser' degree, or not have a default at all?
A: Patients who have CKD stages 1-2 are usually asymptomatic and an eGFR may not always be performed. Therefore if the patient has diabetes with CKD and the diabetes meets ACS 0001/0002 for code assignment a logical default in this instance is to E1-.22 * Diabetes mellitus with established diabetic nephropathy.
+ Obstetrics/Gynaecology
Q: Workshop Obstetrics exercise 3 - In our answers we have assigned the Spontaneous code (O71.11) assuming it was the forces of labour that caused the rupture of the uterus. The patient was given syntocinon and had an epidural during labour. Coders queried why not assign the unspecified code O71.10 or should this have been coded to O71.12 Traumatic as drugs were used?
A: For the scenario used in the workshop the most appropriate code to assign given the limited information provided was O71.11 Spontaneous rupture of uterus during labour, however, we understand that some coders may have wanted to assign O71.10 Rupture of uterus during labour, unspecified based on their interpretation of the case scenario and this is often difficult when the whole record is not available at the time of coding. Code assignment should be based on documentation of the rupture occurring 'spontaneously' or 'traumatically' if in doubt assign the code for unspecified rupture.
Q: Hysterectomy has a code also instruction for debulking of uterus at blocks [1268] and [1269] - is this the same as morcellation?
A: Debulking is the removal of a major portion of the material that composes a lesion, such as the surgical removal of most of a tumour so that there is less tumour load for subsequent treatment by chemotherapy or radiation. Often with uterine tumours they need to be 'debulked' prior to a hysterectomy being performed. This differs from morcellation where there is the division of solid tissue (such as an organ) into pieces, which can then be removed often laparoscopically.
If 'debulking' is documented in the operation report assign 35658-00 [1270] Debulking of uterus preceding hysterectomy.
+ Procedural complications
Q: In ACS 1904 Procedural complications - infected intravenous (IV) sites, the classification section provides advice on:
  • Localised infection - due to device
  • Systemic infection - due to procedure or infusion
What codes would be assigned if a systemic infection that has resulted from the device, i.e. starts as a local infection due to the device, and then progresses to a systemic infection e.g. seen in cancer pts who have a Hickman's who are more prone to developing an infection due to their low immune system?
A: If there is clear documentation in the clinical record that the infection was due to a device and it then becomes systemic assign T82.7 Infection and inflammatory reaction due to other cardiac and vascular devices, implants and grafts and the appropriate sepsis code to capture that it is now a more systemic infection.
Q: The following issues were raised regarding the coding of procedural complications:
  • Coding of CVAs, MI, haemorrhages, hypertension which occur during a procedure (ie intra-operatively) - are these classified to T81.8 Other complications of procedures, not elsewhere classified then the external cause being a misadventure or is the condition really a result of an existing condition and therefore just use the specific chapter code without an external cause code?
  • If the condition doesn't meet the definition for a procedural complication then should the condition be coded in its own right and therefore a T code is not assigned?
  • What codes should be assigned for an intra-operative haemorrhage? - a T code plus a Misadventure external cause code as per ACS 1904 Procedural complications - Definition of a misadventure.
A: If the intraoperative event e.g. haemorrhage, MI, CVA etc meets:
  • the definition of an additional diagnosis as per ACS 0002 Additional diagnoses
  • and
  • the definition for a procedural complication as per ACS 1904, (ie is directly related to the surgical/procedural intervention)
    then for the diagnosis code, apply ACS 1904 and follow the index lookups. This means that the first diagnosis code could come from either the end of chapter codes or the T code section.
    The next code in the string will indicate the condition/problem ie MI, CVA etc and an external cause code will be assigned from Y60-Y69 Misadventures to patients during surgical and medical care, refer to examples 17 and 18 in ACS 1904.
+ Ventilation
Q: If a patient is intubated and ventilated for <1 hour and then transferred to another hospital what codes are assigned?
A: As per ACS 1006 Respiratory support hours of mechanical ventilation should be interpreted as completed cumulative hours (point 1 c.) and any method of intubation for ventilatory support is not coded (point 2 b.). For classification purposes if a patient is intubated and ventilated for less than one hour the intubation and ventilation are not coded. Amendments will be made to ACS 1006 to reflect this advice.
+ Bilateral/multiple procedures
Q: In ICD-10-AM/ACHI/ACS Fifth Edition - ACS 0020 Multiple/bilateral procedures the 'exceptions' at point C read as follows:
(c) Procedures performed without anaesthesia should be coded once only (unless listed in ACS 0042 Procedures normally not coded as a procedure not to code, or unless directed otherwise in another specialty standard).
Examples:
Assign one code if multiple repetitions of the following procedures are performed without anaesthesia:
CT scans (of same site and type)
Blood transfusions (of same product type)
Pain management procedures
Allied health interventions
Haemodialysis
Does this still apply for the coding of CT scans or does the new classification point in ACS 0020 Bilateral/multiple procedures over ride this i.e. 'a procedure which is repeated during an episode of care should be coded as many times as performed'?
A: The NCCH acknowledges the fact that the coding of multiple CT scans was not addressed in the revision of ACS 0020 for Sixth Edition. Therefore if a patient has multiple repetitions of a CT scan performed during an episode of care assign one code only.
    Volume 15 Number 2  September 2008
+ ACS 1618 Low Birth Weight and Gestational Age
    The use of Z51.88 Other specified medical care
The title of this ACS has changed from ‘Prematurity and low birth weight’ to ‘Low birth weight and gestational age’ and the prematurity section in this standard has been deleted.
Previous advice in ACS 1618 included the following:
However, if the infant is > 28 days old and ≥ 2500g on admission, assign Z51.88 Other specified medical care as the principal diagnosis and a code from P07 as an additional diagnosis.
This advice has been amended and incorporated into ACS 1605 where the following excerpt is significant.
Codes from ICD-10-AM Chapter 16 Certain conditions originating in the perinatal period:
  • will still apply for infants > 28 days who are still in the birth episode and
  • will still apply for infants > 28 days who are discharged and subsequently readmitted with a condition documented as originating in the perinatal period.
These changes allow coders to assign the codes for prematurity for babies who are transferred for ‘fattening up’ post premature birth.
Version 6.0 AR-DRGs due for release later this year will allow appropriate grouping of these cases. However, the current and previous versions of AR-DRGs will assign these patients to error DRG 963Z Neonatal diagnosis not consistent with age/weight.
Coders should contact their respective health departments to discuss funding implications of this change to the Australian Coding Standard.
+ Calculi of the vesicoureteric junction (VUJ) and pelvoureteric junction (PUJ)
What are the correct codes to assign for calculi of the VUJ and PUJ?
There are no index entries for calculi of the VUJ or PUJ. Therefore, codes should be assigned based on the higher anatomical site. The correct code to assign for a calculus of the vesicoureteric junction is N20.1 Calculus of ureter and the correct code to assign for a calculus of the pelvoureteric junction is N20.0 Calculus of kidney.
+ Capsular/intracapsular tension ring
Should a separate code be assigned for the insertion of a capsular/intracapsular tension ring during cataract surgery?
It is estimated by the World Health Organization (WHO) that 12 to 15 million people go blind from cataracts and 8 million cataract operations are carried out world-wide each year. Such operations involve surgical removal of the opacified lens and substitution with an artificial intraocular lens.
Capsular/intracapsular tension rings are sometimes used to provide stabilisation of the capsular bag and the intraocular lens both during and after surgery and to prevent capsular bag shrinkage. They may also be used for patients with loose or broken zonules (ligaments that suspend the lens), which may have been weakened or broken due to trauma or disease.
Capsular/intracapsular tension rings are in use in Australian health care but they are not used in every cataract repair. There is still debate as to whether these rings prevent the occurrence of capsular bag shrinkage and whether they are appropriate for use in children.
As capsular/intracapsular tension rings are a component procedure of some cataract operations it is unnecessary to assign a separate code for their insertion as per the guidelines in ACS 0016 General Procedure Guidelines — Procedure components.
+ Central venous and arterial lines
Do you need to assign procedure codes for insertion of central venous and arterial lines when inserted under general anaesthetic during coronary artery bypass grafting?
Insertion of central venous and arterial lines are considered routine for patients undergoing coronary artery bypass grafting. Therefore, it is unnecessary to assign codes for them. However, if they are inserted as a stand alone procedure under an anaesthetic (except local) they should be coded as per the guidelines in ACS 0042 Procedures normally not coded, point b, which states:
“The listed procedures should be coded if anaesthesia (except local) is required for the procedure (see ACS 0031 Anaesthesia).”
ACS 0042 Procedures normally not coded will be reviewed in conjunction with ACS 0909 Coronary artery bypass grafts for a future edition of the ACS.
Note: This advice should also be applied when central venous and arterial lines are performed as a component of any type of surgery.
+ Dental Services (Part 1)
Coding of dental procedures is a very specialised area that requires an understanding of dental terminology and anatomy. This article is part one of a two part article written to assist coders to understand common procedures and terms used in dental services.
In ACHI, Sixth Edition dental intervention codes are based on The Australian Schedule of Dental Services (Eighth Edition) published by the Australian Dental Association incorporated.
+ Tooth Anatomy
Tooth Anatomy
Knowledge of the anatomy of teeth is important in the understanding of both the disease processes and interventions required for the treatment of dental diseases (see Figure 1).
Figure 1 - Tooth Anatomy
Definitions
Enamel - the tough, shiny, white outer surface of the tooth.
Dentin - the hard but porous tissue located under both the enamel and cementum of the tooth. Dentin is harder than bone.
Cementum - the layer of tough, yellowish, bone-like tissue that covers the root of a tooth. It helps hold the tooth in the socket. The cementum contains the periodontal membrane.
Crown - the visible part of a tooth.
Tooth root - the portion of the tooth that lies beneath the gum line and is embedded in bone. The tooth root serves as an anchor to hold the tooth in position.
Pulp - the soft inner structure of a tooth consisting of nerve and blood vessels.
Gingiva - the gum.
Deciduous teeth - the primary or baby teeth; the first set of teeth that are later replaced by permanent teeth.
Exfoliation - the process by which the deciduous teeth fall out to make way for the eruption of permanent teeth.
Eruption - the process by which the teeth break through the gums.
Figure 2 - Types of Teeth
Incisors - the four front teeth in the lower and upper jaw are called incisors. The central pair in the lower and upper jaw are called central incisors and the teeth on either side of the central incisors are called lateral incisors. These teeth are broad and flat with a narrow edge that is used for cutting or snipping off pieces of food.
Canines - the four canine teeth are situated next to the lateral incisors on the lower and upper jaw. They are also referred to as eyeteeth or cuspids. Canines are the longest and most stable teeth in the mouth. They are used to rip and tear food and have a single long root.
Premolars - next to each of the canine teeth are two premolars, also referred to as bicuspids. These teeth are a cross between canines and molars. Like the canine teeth, premolars have sharp points for ripping; however, they also have a broad surface, like molars, for chewing and grinding.
Molars - these are the last three teeth on both sides of the mouth, in the upper and lower jaw. They are numbered first, second or third molar according to their location.
The third molars are also referred to as wisdom teeth. Wisdom teeth are the last teeth in the mouth and are the last teeth to erupt. Molars are the largest teeth in the mouth. They have a broad surface that is used for crushing, grinding and chewing food.
+ Dental notation
Dental notation
Tooth numbering systems are used by dentists to associate information to a specific tooth. These notation systems are used in medical records and operation reports to help to identify which specific tooth is being treated. Two common tooth numbering systems used in Australia are the Federation Dentaire Internationale (FDI) Two Digit Notification method and the Palmer notification method.
FDI Two Digit Notification Method
This notification method is a combination of two numbers. The first number indicates the tooth's location (upper left or right, lower left or right) and the second number indicates the specific tooth (see Table 1).
+ Palmer notification method
Permanent teeth
In this method, the teeth are also divided into quadrants and are numbered from 1 to 8 in the same manner as the FDI notification method. The method of identifying the specific quadrant however is different. Each quadrant is identified by an shaped symbol. The number of the tooth then sits inside the shaped symbol. The refers to teeth in the upper right quadrant, the refers to teeth in the upper left quadrant. The lower quadrants are identified by the upside down shaped symbols. The refers to the lower right quadrant and the refers to the lower left quadrant (see Figure 4 and Example 1).
Deciduous teeth
The Palmer notification method has a different method of numbering deciduous teeth. The teeth are identified by the letters A to E. The teeth are assigned a letter starting at the central incisor (A) and working toward the 3rd molar (E). The system for the identification of the tooth's position is exactly the same as for permanent teeth (see Figure 5 and Example 2)
+ Position of teeth
Position of teeth
Anterior - are the teeth in front of the mouth, e.g. central incisors, lateral incisors and cuspids.
Posterior - are the teeth at the back of the mouth including molars and bicuspids.
+ Tooth Surfaces
Tooth Surfaces
There are five possible tooth surfaces that can be restored - buccal, distal, lingual, mesial, and occlusal/incisal (see Figure 7).
Buccal - is the surface of the tooth that faces toward the cheek.
Distal - is the proximal surface that is orientated away from the midline of the dental arch. It is the opposite of mesial.
Lingual - is the tooth surface next to the tongue.
Mesial - is the proximal surface that is closest to the midline of the dental arch.
Occlusal - is the surface of the tooth that has contact with the opposing tooth.
Incisal - is the surface of the tooth that has contact with the opposing anterior teeth. It refers to the cutting edge of an incisor or canine tooth.
Dental arch - is the curved structure that is formed by the teeth in their normal position.
+ Dental restorations
Dental restorations
Dental restorations or fillings are used to restore function and integrity to the structure of teeth. The most common causes for the loss of tooth structure are dental caries or tooth trauma.
Dental restorations are classified into two types, direct and indirect (see Table 3).
Direct restorations are performed by placing the restorative material directly onto the tooth. These types of restorations are usually performed in one visit and examples include dental amalgam, glass ionomers, resin ionomers and resin composite fillings.
Indirect restorations involve materials that have been fabricated outside the mouth. Examples include: inlays, onlays, veneers, crowns and bridges.
+ Removal of teeth
Removal of teeth
Non-surgical extraction - also referred to as simple extraction, is generally performed under local anaesthetic and is performed on teeth that can be seen in the mouth. The tooth is held with forceps which are then moved back and forth to loosen the tooth until it is removed. Sometimes a luxator is used to help loosen the tooth before it is extracted.
Surgical extraction - an incision is made into the mucosa and a mucoperiostial flap is raised in order to extract the tooth. In some cases, the tooth will need to be broken into sections to be removed. Surgical extractions may involve teeth that are not visible in the mouth either because the tooth has broken off or has not yet erupted through the gum. Surgical extractions are also performed if a tooth is impacted.
Tooth impaction - occurs when a tooth fails to erupt through the gum (or only partially erupts) at the expected time. Wisdom teeth, the last teeth to erupt, are the most common teeth to become impacted.
There are four types of tooth impaction - erupted (already in the mouth), full bony impaction (see Figure 8), partial-bony impaction (see Figure 9), and soft tissue impaction (see Figure 10). An impacted tooth may be painless. However, pain and swelling occurs when the tooth tries to erupt through the overlying gum. Pain may be felt in nearby teeth or the ear on that side. A partially erupted tooth may collect food and debris leading to gum swelling and pericoronitis
+ Types of tooth impaction
+ Removal of impacted teeth
The procedure for the removal of wisdom teeth varies according to the type of impaction. Wisdom teeth may grow in different directions due to lack of space in the jaw. As a result, the complexity of the surgery depends on the type of impaction. If the tooth has erupted fully, it may be removed by a simple extraction. However, a full bony impaction will require a complex surgical extraction.
Impacted wisdom teeth are generally removed by surgical extraction. An incision is made into the gum and the gum tissue is moved out of the way. This exposes the tooth and the bone overlying it. In order to access the tooth, any bone in the way needs to be carefully removed. Once the tooth is exposed, it may need to be broken into pieces or sectioned in order to be removed. Sectioning the tooth enables the tooth to be removed through the smallest possible incision, with the loss of the least amount of bone. Sectioning the tooth also protects important nerves and blood vessels that surround the tooth. Once the tooth has been removed, the gum tissue is replaced and the wound is sutured.
+ Bibliography
American Dental Association, Dental filling options. Accessed 12 November 2007. http://www.ada.org/public/topics/fillings.asp
WMDS Inc, Impacted wisdom teeth/wisdom tooth extraction. Accessed 12 November. 2007. http://www.animated-teeth.com/wisdom_teeth/t4_impacted_wisdom_tooth.htm
Colgate-Palmolive Company, Tooth extraction. Accessed 12 November 2007. href="http://www.colgate.com/app/Colgate/US/OC/Information/OralHealthBasics/CheckupsDentProc/ToothRemovalExtraction/ToothExtraction.cvsp
Findadentist.net Dental glossary. Accessed 12 November 2007. http://www.findadentist.net/glossary.htm
Integrated publishing, Tooth surfaces. Accessed 12 November 2007. http://www.tpub.com/content/medical/14275/css/14275_58.htm
Columbia University College of Dental Medicine, Simple steps to better dental health. Accessed 12 November 2007 http://www.simplestepsdental.com/SS/ihtSS/r.WSIHW000/st.31819/t.31819/pr.3.html
SweetHaven Publishing Services, Fundamentals of dental technology. Accessed 12 November 2007. http://www.free-ed.net/sweethaven/MedTech/Dental/Dental01/Dental01_v1.asp
Web Dental Office, Tooth numbering system. Accessed 12 November 2007. http://users.forthnet.gr/ath/abyss/dep1151_1.htm
+ Dental Services (Part 2)
This is the second of a two-part series to provide guidance on the coding of dental procedures. It provides advice on the classification of dental procedures and tables listing the types of interventions that may be performed.
In ACHI, Sixth Edition dental intervention codes are based on The Australian Schedule of Dental Services and Glossary (8th Edition) published by the Australian Dental Association Incorporated (see reference details below).
+ Classification
Classification
Dental procedures should be coded following ACS 0016 General procedure guidelines, and ACS 0809 Intraoral osseointegrated implants. Dental procedures are excluded from ACS 0020 Bilateral/multiple procedures.
This standard instructs that procedures which are individual components of another procedure should not be coded. For example, fissure sealing may be performed alone or it may be performed as part of tooth preparation for a restoration procedure. In this latter instance, the fissure sealing procedure should not be coded.
The intraoral osseointegrated implants procedure is a complicated two stage procedure. This standard provides guidelines to assist with coding in this area.
Codes in Chapter 6 Dental services do not meet the criteria in ACS 0020 Bilateral/multiple procedures for ACHI Sixth Edition. Generally, dental procedures should be coded as many times as they are performed. However, the following guidelines should be applied to the coding of dental procedures:
  • When a code includes reference to a number of teeth, it should only be assigned once. For example, 97311-03 [457] Removal of 3 teeth or part(s) thereof specifies the removal of 3 teeth therefore this procedure code should only be assigned once.
  • Dental codes that specify per tooth, per root or per cusp (etc) should be coded as many times as they are performed. For example, 97171-00[455] Odontoplasty, per tooth should be coded as many times as it is performed.
  • Codes that don't indicate a specific number of teeth should be coded as many times as performed. For example, if documentation specifies 97414-00 [462] Pulpotomy was performed on four teeth, it should be assigned four times.
+ ACHI Sixth Edition
In ACHI Sixth Edition, a range of codes have been created to reflect the number of teeth extracted; - 1 tooth, 2 teeth, 3 teeth, 4 teeth, 5-9 teeth, 10-14 teeth and ≥15 teeth. These values have been added to the codes in blocks [457] Nonsurgical removal of tooth and [458] Surgical removal of tooth to simplify the code selection when the mucosa has been incised and the mucoperiosteal flap raised. Multiple codes will no longer need to be assigned for the surgical and nonsurgical extraction of teeth.
The distinction between surgical extraction of teeth and nonsurgical extraction of teeth is not always clear. Amendments have been made to ACHI Sixth Edition to clarify the difference. Documentation of 'incision of mucosa' is an indication of a surgical tooth extraction. Therefore, the following inclusion terms have been added to aid code selection:
  • 'Incision of mucosa and raising of mucoperiosteal flap to remove tooth, followed by suturing of the wound' in block [458] Surgical removal of tooth
  • 'Extraction of tooth without incision of mucosa' in block [457] Non surgical removal of tooth.
A full dental clearance is the process whereby all remaining teeth in the mouth are removed. That is, no teeth remain in the mouth after the procedure. A definition has been added to 97322-01 [458] Full dental clearance to clarify the meaning of the term. Codes have been created for a 'full upper clearance' and a 'full lower clearance'. A 'full upper clearance' is when there are no teeth remaining in the upper jaw after the procedure and a 'full lower clearance' is when there are no teeth left in the lower jaw after the procedure.
+ ACHI Dental procedures and definitions
NCCH published tables in Coding Matters Vol 7, No 3 containing commonly performed dental procedures with definitions. The following tables are an update of the previously published information.
+ Preventative
+ Periodontic Interventions
+ Oral Surgery
+ Endodontics
+ Restorative Types
+ Prosthodontics
+ Orthodontics
+ General Dental Services
+ Bibliography
Australian Dental Association Inc. (2004), The Australian Schedule of Dental Services and Glossary (8th ed.), Australian Dental Association, Sydney.
+ Diabetes mellitus and blood sugar levels (BSLs)
The ICD-10-AM Third Edition Education Program Frequently Asked Questions (FAQs) — part 2 — contained the following advice:
‘Diabetes should be coded when it meets the criteria in ACS 0002 Additional diagnoses. The taking of BSLs is one indication that diabetes mellitus meets the criteria of ACS 0002.’
This advice was also published on the NCCH Queries Database.
ACS 0002 Additional diagnoses has been revised for the ACS Sixth Edition. During the revision process, the issue of diabetes and BSLs was discussed by the NCCH and the Coding Standards Advisory Committee (CSAC). Both the NCCH and CSAC subsequently supported the advice that diabetes should only be coded when it meets the criteria in ACS 0002. Revision to ACS 0002 advises:
“The national morbidity data collection is not intended to describe the current disease status of the inpatient population but rather, the conditions that are significant in terms of treatment required, investigations needed and resources used in each episode of care.
For coding purposes, additional diagnoses should be interpreted as conditions that affect patient management in terms of requiring any of the following:
  • commencement, alteration or adjustment of therapeutic treatment
  • diagnostic procedures
  • increased clinical care and/or monitoring.”
The above criteria should be applied to each individual case in order to determine the appropriateness of assigning codes for diabetes mellitus. Coders should not automatically assign diabetes codes when BSLs are documented in the clinical record. BSLs are routinely recorded for many diabetic patients and should therefore not be assumed to indicate increased clinical care or monitoring.
As this advice may lead to a change in coding practice for some coders it is effective from the implementation of ICD-10-AM Sixth Edition, July 2008.
+ Diarrhoea due to Clostridium difficile
What is the correct code to assign for diarrhoea due to Clostridium difficile?
Clostridium difficile is the most common cause of infectious hospital-acquired diarrhoea in developed countries. Although in most cases it causes a relatively mild illness, occasionally, and particularly in elderly patients, it may result in serious illness and even death. The bacterium produces two toxins which are responsible for the diarrhoea and which damage the cells lining the bowel. However, not all strains of C. difficile produce toxin; these strains are unlikely to cause disease and patients colonised by them remain healthy.
Almost all patients who develop C. difficile diarrhoea are taking, or have recently been given, antibiotic therapy. Diarrhoea is the most common symptom but abdominal pain and fever may also occur. In the majority of patients, the illness is mild and full recovery is usual, although elderly patients may become seriously ill with dehydration as a consequence of the diarrhoea. Occasionally patients may develop a severe form of the disease called pseudomembranous colitis, which is characterised by significant damage to the large bowel.
The current index pathway directs coders to assign A04.8 Other specified bacterial intestinal infections. However, clinical advice received by the NCCH indicates that the correct code to assign is A04.7 Enterocolitis due to Clostridium difficile.
The indexing of this condition will be reviewed for a future edition of ICD-10-AM.
This advice highlights a change to current coding practice and is effective from the implementation of ICD-10-AM Sixth Edition, July 2008.
+ Dropped lens/nucleus
What is the correct code to assign for dropped lens/nucleus?
Clinical advice regarding dropped lens/nucleus indicated the following:
“There are two types of lenses that can drop; the human crystalline lens (which can become cataractous) and an intraocular lens.
The most common cause of ‘dropped’ cataractous lens is when (usually) part of the lens is dropped during cataract surgery, typically the nucleus of the lens. This occurs either because of a hole being torn in the capsule of the lens or because the attachments of the lens to the ciliary body via the zonular fibres are weak and disrupted by the trauma of the surgery.
Intraocular lenses can be dropped at the time of surgery, usually where the capsule is torn. They can also dislodge later in the post-operative course, depending largely on how they have been fixated. Typically, lenses placed in the so called ciliary sulcus are dislodged. Late dislodgement can occur when the capsular bag dislodges from the ciliary body. The alignment of the intraocular lens can also change in the longer term because of particular patterns of fibrosis in the capsular bag.”
When lens fragments/nucleus are dropped into the vitreous cavity after a capsular breach, assign:
T81.2 Accidental puncture and laceration during a procedure, not elsewhere classified
S05.8 Other injuries of eye and orbit
Y60.0 Unintentional cut, puncture, perforation or haemorrhage during surgical and medical care, During surgical operation
Y92.22 Health service area
Where there is a later displacement of the lens, without documentation of a capsular breach, assign:
T85.2 Mechanical complication of intraocular lens
Y83.1 Surgical operation and other surgical procedures as the cause of abnormal reaction of the patient, or of later complication, without mention of misadventure at the time of the procedure, Surgical operation with implant of artificial internal device
+ Jejunotomy with removal of calculus
Patient admitted with gallstone ileus. What is the correct code to assign for jejunotomy (open procedure) with removal of calculus and cholecystotomy?
The following codes should be assigned for the abovementioned procedures:
30375-03 [893] Enterotomy of small intestine
30375-26 [963] Cholecystotomy
+ Malnutrition
The NCCH and CSAC have agreed that malnutrition may be coded when it is documented by a dietitian in the clinical record. This decision is supported in the Introduction to the Australian Coding Standards (ACS) as follows:
“The term ‘clinician’ is used throughout the document and refers to the treating medical officer but may refer to other clinicians such as midwives, nurses and allied health professionals. In order to assign a code associated with a particular clinician’s documentation, the documented information must be appropriate to the clinician’s discipline.”
Dietitians meet the definition of a clinician in the ACS and diagnosis and treatment of malnutrition is appropriate to their profession.
Malnutrition must meet the criteria in ACS 0001 Principal diagnosis or ACS 0002 Additional diagnoses to be coded.
+ Seprafilm®
Is it necessary to assign a code for Seprafilm® inserted during a procedure?
To reduce the occurrence of adhesions following surgery, surgeons can use adhesion barriers to separate tissue and organs while the body heals. Seprafilm® is a type of adhesion barrier composed of chemically modified sugars, some of which occur naturally in the human body. It is a clear film that sticks to the tissues to which it is applied and is slowly absorbed into the body over a period of seven days. It is placed at sites of tissue injury during surgery (commonly abdominal and pelvic surgery) to help prevent the formation of adhesions between tissues and organs.
The insertion of Seprafilm® is a prophylactic measure which is completely absorbed into the body and does not require removal. It is unnecessary to assign a code for this procedure.
+ Slow coronary flow/slow flow syndrome
What is the correct code to assign for slow coronary flow/slow flow syndrome?
The concept of slow coronary flow was first diagnosed in 1972. The coronary slow flow phenomenon is an angiographic finding characterised by delayed distal vessel opacification in the absence of significant epicardial coronary disease. It typically presents as persistent chest pain or angina pectoris and can significantly impair quality of life.
Clinical advice indicates that this is not a new syndrome but is more frequently identified now due to an increase in the number of angiograms performed. The correct code to assign for slow coronary flow syndrome is I20.8 Other forms of angina pectoris.
+ VADs, VCs and DDDs
    Vascular Access Devices, Venous Catheters And Drug Delivery Devices
Vascular access devices
ACHI defines a vascular access device (VAD) as an implanted venous catheter with a reservoir attached. The subcutaneous reservoir is designed to accept multiple punctures from special types of needles (e.g. Huber or Gripper needles) and may be accessed to withdraw fluid or to infuse substances. A Port-A-Cath is a type of VAD used in Australian facilities.
Classification
Where patients are admitted for adjustment, management, fitting or removal of a vascular access device, assign:
Z45.2 Adjustment and management of vascular access device
ACHI codes for insertion, revision and removal of VADs are in block [766] Vascular access device
Example 1
Same-day admission for removal of Port-A-Cath. Device removed under sedation. Assign:
34530-05 [766] Removal of vascular access device Sedation
ACHI also contains a code for maintenance of vascular access devices:
13939-02 [1922] Maintenance (alone) of vascular access device
Example 2
Same-day admission to check patency of Port-A-Cath, which had been inserted the previous week. Device accessed for pathology and flushed with heparin. Assign:
Note: Activities such as withdrawal of fluid for culture and flushing of a vascular access device are routine components of administration of pharmacotherapy. Therefore, when assigning a code from block [1920] Administration of pharmacotherapy, it is not necessary to also assign 13939-02 [1920] Maintenance (alone) of vascular access device.
Example 3
Patient admitted for same-day episode of care for chemotherapy for their neoplasm. Port-A-Cath accessed for pathology and chemotherapy administered. Port flushed and heparin locked. Patient discharged home. Assign:
Z51.1 Pharmacotherapy session for neoplasm Neoplasm codes
96199-00 [1920] Intravenous administration of pharmacotherapy agent, antineoplastic agent
Vascular/venous catheters
In ACHI, central venous catheters that don‘t have subcutaneous reservoirs (Hickman‘s, PICC lines) are classified as vascular/venous catheters and not as vascular access devices.
Classification
Where patients are admitted for adjustment, management, fitting or removal of vascular/venous catheters (without reservoirs), assign:
Z45.8 Adjustment and management of other implanted devices
ACHI codes for insertion and removal of vascular/venous catheters (Hickman‘s, PICCs and CVCs) are in block [738] Venous catheterisation.
Example 4
Same-day admission for insertion of a Hickman‘s line. Line inserted using sedation. Assign:
13815-01 [738] Percutaneous central vein catheterization Sedation
Example 5
Same-day admission for flushing of PICC line and change of dressing surrounding the catheter. Procedures performed and patient returned home. Assign:
92058-00 [1890] Irrigation of vascular catheter
Drug delivery devices
A drug delivery device is a piece of equipment used to administer pharmacological substances.
An ambulatory, external infusion pump is a type of drug delivery device that is attached to a vascular access device to infuse substances over long periods. The pump is computerised to allow the administration of a prescribed dose and rate of medication over a defined time period. External drug delivery devices may also be attached to venous catheters (without reservoirs) — for example, a Hickman‘s Drug delivery devicess line - or other, nonvascular catheters for administration of pharmacological agents via other routes — for example, for the subcutaneous administration of insulin (via an insulin pump).
ACHI also contains codes for implantable drug delivery devices, such as the implantable spinal infusion device or pump. These devices administer drug therapy for pain control directly into the intrathecal space. A catheter is inserted into the spinal canal and attached to a pump implanted in the abdomen or chest wall.
Classification
Where patients are admitted for adjustment, management, fitting or removal of a drug delivery device, (except for loading of a drug delivery device for same-day admission of chemotherapy to treat a neoplasm — see examples 7 and 8) assign:
Z45.1 Adjustment and management of drug delivery device
ACHI codes for insertion, replacement or removal of an implantable spinal infusion device or pump are:
39127-00 [39] Insertion of implantable spinal infusion device or pump
39126-00 [56] Revision of implantable spinal infusion device or pump
39133-02 [40] Removal of implantable spinal infusion device or pump
Example 6
Same-day admission for removal of spinal infusion device. Device removed under sedation. Assign:
39133-02 [40] Removal of implantable spinal infusion device or pump Sedation
ACHI also contains codes for loading and maintenance of drug delivery devices:
96209-xx [1920] Loading of drug delivery device
13942-02 [1922] Maintenance (alone) of drug delivery device
Note: External drug delivery devices (infusion pumps) are not inserted into the body — they are attached to VADs or venous or other catheters. Therefore, procedure codes should only be assigned for loading or maintenance of the device, as appropriate.
Where patients are admitted for a same-day episode of care for chemotherapy for a neoplasm and have their drug delivery device loaded, assign:
Z51.1 Pharmacotherapy session for neoplasm (see ACS 0044 Chemotherapy)
Example 7
Same-day admission for chemotherapy for treatment of a neoplasm via an external drug delivery device (CADD pump). The CADD pump was set for 7 days at a dose of 200mg per 24 hours and attached to the patient's Port-A-Cath (which had been inserted on a previous admission). Assign:
96209-00 [1920] Loading of drug delivery device, antineoplastic agent
Example 8
Same-day admission for chemotherapy for treatment of a neoplasm. Port-A-Cath (which had been inserted on a previous admission) accessed for pathology, then chemotherapy administered. On completion, the patient's CADD pump was filled with antineoplastic agent and attached to the Port-A-Cath for continued infusion at home. Assign:
96199-00 [1920] Intravenous administration of pharmacological agent, antineoplastic agent
+ Bibliography
ASERNIP-S, Australian Safety and Efficacy Register of New Interventional Procedures - Surgical, Rapid Review, Intracapsular Tension Ring, September 2001, The Royal Australasian College of Surgeons. Accessed 12 May 2008. http://www.surgeons.org/AM/Template.cfm?Section=Home&TEMPLATE=/CM/ContentDisplay.cfm&CONTENTID=4853
Association of Medical Microbiologists, Facts about Clostridium difficle infection. Accessed 26 October 2007. http://www.amm.co.uk/files/factsabout/fa_cdiff.htm
Beltrame JF, Limaye SB, Horowitz JD, The Coronary Slow Flow Phenomenon - A New Coronary Microvascular Disorder, Cardiology, International Journal of Cardiovascular Medicine, Surgery, Pathology and Pharmacology, Vol. 97, No. 4, 2002, pages 197-202. Accessed 12 May 2008.
Chee S-P, Cataract and Refractive Surgery Today, PAL of a Dropped Nucleus. Accessed 15 February 2008. http://www.crstodayeurope.com/Issues/0307/f6_chee.html
Riley TV, Epidemic Clostridium difficile, eMJA, The Medical Journal of Australia, Vol. 185, No. 3, 2006, pages 133-134. Accessed 12 November 2007. http://www.mja.com.au/public/issues/185_03_070806/ril10472_fm.html
Fazio VW, Cohen Z, Fleshman JW et.al., Reduction in Adhesive Small-Bowel Obstruction by Seprafilm® Adhesion Barrier After Intestinal Resection, (Dis Colon Rectum 2005 49 (1): 1-11), Presentation at Prince of Wales Hospital Journal Club by Dr Anita Jacombs BST. Accessed 12 May 2008. http://www.sesiahs.health.nsw.gov.au/powh/General%20Surgery/Journal%20Club/POWH%20Journal%20Club.ppt
Genzyme Australasia, Seprafilm®. Accessed 12 May 2008. http://www.genzyme.com.au/prod/sepraf/au_p_hcp_bio-seprafilm.asp
Intermedex, Ultrasonic Phacoemulsification Handpieces. Accessed 15 February, 2008. http://www.intermedex.com/phaco.html
Li J-J, Wu Y-J, Qin X-W, Should slow coronary flow be considered as a coronary syndrome? Medical Hypotheses, Vol. 66, No. 5, 2006, pages 953-956, ScienceDirect, Health Science Journals. Accessed 12 May 2008.
Visitech, Visitech Eye Hospital, Dropped Lens. Accessed 6 February 2008. http://www.visitech.org/case-dropped-lens.html
