Performance Indicators for Coding Quality (PICQ) 2008
A powerful ICD-10-AM/ACHI code analysis tool to
monitor, measure and evaluate coding quality and to facilitate
improvement in coding quality
The NCCH is pleased to announce the release of PICQ 2008, a powerful ICD-10-AM/ACHI code analysis tool to monitor, measure and evaluate coding quality and to facilitate improvement in coding quality
What is PICQ?
PICQ is a series of indicators which analyse admitted patient
morbidity data coded with ICD-10-AM and the Australian Classification
of Health Interventions (ACHI) and is based on Australian
Coding Standards (ACS) and coding conventions. Users link
their coded data to the PICQ database and the records are then
compared to the predetermined indicators that test coding quality.
The indicators identify records that contain a coding error (or
possible coding error) in diagnosis and procedure codes or a National
Health Data Dictionary (NHDD) field, such as age. The indicators
are categorised
according to the type of problem the indicator
seeks to identify.
What does PICQ do?
PICQ indicators analyse disease and procedure codes:
- in combination with other codes and/or
- in combination with NHDD data items
- and/or in a sequence and/or
- for their presence or absence and/or
- for their specificity
top
Examples of PICQ indicators (in
narrative terms):
PICQ indicators are categorised according to the type of problem
the indicator seeks to identify. Following are some examples of
indicators according to indicator type:
Edit problem
Indicator 100367 External cause code as principal diagnosis
identifies records with an external cause code as principal
diagnosis. ACS 2001
External cause code use and sequencing states
that external cause codes must never be the principal diagnosis:
the principal diagnosis is the injury, poisoning, and so forth.
Completeness problem
Indicator 100331 Type of spinal cord lesion code without functional
level of spinal cord lesion code identifies records containing
a type of spinal cord lesion code but no functional level of lesion
code. ACS 1915 Spinal (cord) injury states that a spinal cord
injury, in the initial stage post trauma, should be coded in this
sequence: type of cord lesion (complete/incomplete), functional
level of spinal cord lesion, and, if appropriate, vertebral injury
(fracture, dislocation).
Redundancy problem
Indicator 101401 Harmful use of tobacco code with specific
related disorder code identifies records containing both
a harmful use of tobacco code and a specific tobacco related disorder
code. ACS 0503 Drug and alcohol use disorders states that, ?harmful
use? of a substance cannot be coded if a specific related disorder
is present for that substance. The harmful use is implicit in
these other conditions.
Specificity problem
Indicator 101986 Oesophageal varices code with underling cause
code identifies records containing an oesophageal varices
code and a specific underlying cause code, but not a manifestation/aetiology
code combination. Oesophageal varices in or due to alcoholic liver
disease, toxic liver disease, cirrhosis of the liver or schistosomiasis
should be assigned an aetiology (dagger)/manifestation (asterisk)
code combination as instructed in the Alphabetic Index of Diseases,
rather than unrelated codes for the two conditions.
Sequencing problem
Indicator 100191 Gastritis code as principal diagnosis followed
by gastric ulcer code identifies records with gastritis as
principal diagnosis followed by a gastric ulcer code. ACS 1106
Gastric ulcer with gastritis
states that, where both gastric ulcer
and gastritis are present, the gastric ulcer code should be sequenced
before the gastritis code.
top
10 good reasons to use PICQ
- identify actual coding errors and possible coding problems
- identify specific records for correction, if necessary
- suggest possible problem causes
- suggest possible corrections
- measure data accuracy against particular indicators
- measure data quality over time
- provide continuous review and amendment of coded data
- provide feedback to individual coders and assist coder education
- benchmark results with similar hospital or health organisation
- complement existing coding audit activities
Who would benefit from using PICQ?
PICQ is a valuable addition to the coding and data quality initiatives
conducted by a wide cross-section of people in the health industry
including:
- clinical coders
- health information managers
- casemix analysts
- data managers
- coder educators
- researchers
- clinicians
- health administrator or managers
- health department officials, especially those in policy and
planning
- private health insurers
top
The PICQ 2008 CD-ROM package
The PICQ 2008 CD-ROM package includes:
- two Microsoft Access® databases (Access2000® and Access2003®)
for ICD-10-AM/ACHI/ACS First, Second, Third, Fourth and ICD-10-AM/ACHI/ACS Fifth
Editions
- step-by-step installation directions
- comprehensive instructions on how to use PICQ
- a sample casemix database containing a limited number of patient
episodes to allow users to become familiar with the program
before linking their own data
- a readme.txt file that contains notes on system requirements
and installation of PICQ
- PICQ 2008 licence agreement
- documents outlining a summary of changes between PICQ 2004
and PICQ 2008 for Fourth and Fifth Editions
System requirements
Microsoft Access2000® or Access2003® must be installed on your
computer in order to run PICQ. A 166MHz Pentium® processor or
higher, 32 MB of memory, 15MB of disk space and a CD-ROM drive
are required.
top
How to order PICQ 2008
PICQ can be ordered by downloading and faxing the
order form to us.
PICQ 2008 demonstration
If you are interested in seeing a demonstration of PICQ 2008
or if you require further information contact NCCH on telephone
+61 2 9351 9461.
If you are interested in PICQ, you may also be interested
in another NCCH quality product, Australian
Coding Benchmark Audit? (ACBA), a coding audit tool based
on recoding a sample of patient episodes to identify coding discrepancies
and distinguish between coder errors and system errors.
PICQ 2006 v5.0 July 2006 is also available, contact NCCH for further information. PICQ 2006 incorporates indicators for ICD-10-AM/ACHI/ACS First Edition (118 indicators), Second Edition (117 indicators), Third Edition (126 indicators) Fourth Edition (223 indicators) and Fifth Edition (248 indicators).
top
